Sofa King. We, Todd, Ed.
Transmission case broke....again.
I've been told that this isn't uncommon? Twice now I have completely cracked the case all the way around the tail shaft on a turbo 350 in a 71 Blazer. Someone mentioned a heavier duty K-Case? for the trans. Also heard about some extra bracing around the t-case?
It is a lame design how the trans is only supported by hanging between the motor and transfer case. I was thinking of building a cross-member for an actual trans mount or even a cradle to connect the motor to the trans to the t-case. Someone suggested I loosen some of the t-case crossmember bolts to allow for flex?? Really? Any ideas and/or pictures would be greatly appreciated!!
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon |
Re: Transmission case broke....again.
There`s nothing lame about how the transmission is mounted.I`ve seen what you do and can see how it breaks
350TH are notorius for cracking when the engine moves because of torque, especially when you get off and on it hard. Transmission is restrained at the back by the mount and weight of the transfercase, engine moves and bang goes the aluminum case, usually across the bell portion around the fluid inlet lines. Solution is to fit a mount (chain, cable or slotted bracket) on drivers side that allows normal (1" or so) movement but stops rotation when the engine accelerates and rotates.
I busted the TH400 K-case in my`84 K/30,so I don`t have room to talk.I was very hard on that truck.
I broke a TH350 around the tail shaft on my 72 Blazer. I put in a DIY engine crossmember, new bushings for the TC torque mount, new mounts at the adapter, and i made a turnbuckle with heim joints to go from the cylinder head down to the frame. So far so good. Its been in there about 2 yrs.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania Last edited by OLDCHEV4X4; 01-03-2010 at 12:12 PM. |
#6 | |
The 205/th350 combos in the later 70's have a solid rod brace that goes from the 2 BIG bolt holes on the passenger side of the t-case up to one of the bellhousing bolts at the motor to help combat this problem. I had this happen alot in my 1 ton '80 blazer before I swapped it for a 400/205. Make sure you use NEW high quality mounts at your motor and t-case. I went to polyurethane mounts, but I'm sure you can use good quality OEM mounts with good results. Dont forget your body mounts too. In my opinion the body mounts are just as important as your motor and tranny mounts. As body mounts wear out they actually allow your frame to flex more than it did when you first start wheeling these things, thats my opinion of why you kind of just "all the sudden" start cracking the housings out. Alot of my wheeling buddies have made stout cradles from steel the tie the 4 rear bolts to a couple of the bellhousing bolts with good results. You may also think about boxing your frame if you are wheeling it pretty hard. Good luck!
#8 | |
Certified Hobbiest
here is the last auto i owned....proud to say i own nothing but manual trucks
mitch 87 chevy short box 4wd tbi 350/built 700r4/np208 3.73s |
Do you have the brace that uses the two holes on the passenger side of the transfer case? We broke a couple of cases in Mom's blazer until we put that brace on. Its been through 3 years in a 700 hp mud truck with no more breakage since.
Oopps!
![]() I never have wheeled a slush box rig before..me like SM465 ![]() I don't think looseing the crossmember for flex is a good idea at all ![]() Good Luck ![]() ![]() ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
#13 | |
Transmission cradle.....OVERKILL!
......still not done yet. ![]()
#15 |
gets board easy.......
wow dude, overkill is right, but a good idea. good thing you have room with that body lift.
and if it helps, ive broken 2 TH350 Cases in a 2wd before........getting traction always brings other problems |
#16 |
Certified Hobbiest
overkill...yes. but it looks like itll fix the problem....or atleast this one.
#17 |
Second Chance Program
I like that idea!
#18 |
dude !!! from the pics that ive seen of you wheelin ... that aint overkill !!!
#19 |
Another Day, Another Dollar
my lord....
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
#20 |
Haha, my lord indeed, wait until you see the finished product. I think I lost my mind and went way way overboard. I guess if you're gonna do something you might as well over do it.
![]() More pix after paint.
#21 |
Strange Cousin From The West..
Overkill would be building some Boxed frame mounts and Tying it to the Frame.
![]() Last edited by Shaffer4; 01-08-2010 at 06:21 AM. |
#22 | |
Sticker on my helmet and words to live by
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
#23 |
YYYYYYYYYYYEEEEEEEEEEHHHHHHAAAAAAAAAAAAAAA!!
![]() That otta hold er together ![]() ![]() ![]() ![]()
#24 |
Some one is going to have fun with the cooler lines and fill tube. Looks like a custom hump will be in order too.
#25 |
You could eliminate your frame and go unibody with that.
