newbie question bed reomval
im sorry for such a silly question been lurking in the darkness on here trying to learn as much as i can but now im stuck i have a a 1970 gmc c-20 and can not figure out what bolts do i take of to remove the bed. i have removed the wood just the main rails holding the bed to the frame but can not figure it out if i need to cut or just unbolt thanks guys for takeing the time to answer a silly question
Re: newbie question bed reomval
![]() couple problems with this post though, you are posting in the 73-87 projects and builds section. You will probably want to post this in the 67-72 section. but to answer your question, there should be 6 or 8 bolts that go directly to the frame that you need to remove and the bed will come off with the wood floor intact.
thank you
no problem
