Old 01-02-2010, 02:38 PM   #1
nutsforchevys
nutsforchevys's Avatar
Can anyone run numbers on axle?
If I provide the stamped numbers on my axles on a 79 4x4 Jimmy, can anyone tell me what the ratio is?
72 Super Cheyenne lwb 4X4 Ocra / White
88 Chevy 1 ton Dumptruck
88 Chevy 1ton Flat bed 4X4 white
nutsforchevys is offline   Reply With Quote
Old 01-02-2010, 03:31 PM   #2
b454rat
Re: Can anyone run numbers on axle?
They have to be on the ring gear itself, GM doesn't use BOM numbers like Dana.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 01-02-2010, 06:15 PM   #3
nutsforchevys
Well as I expected the front and back axles are different
Back has 43 on ring 14 on pinion = 3.07
Front has 41 on ring and 14 on pinion = 2.93
Does this sound right for the front axle?
Old 01-02-2010, 06:33 PM   #4
LONGHAIR
Not really? Are you sure about that count? Did you actually count the teeth or were those the numbers stamped on the ring gear?
As b454rat said, the numbers on the outside can't tell you much, but the numbers that are actually on the ring gear do indicate the ratio.
Is this an automatic truck? Stick shift Blazers and Jimmys in the square body are are not that common
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-02-2010, 06:52 PM   #5
nutsforchevys
I counted the teeth. It is a automatic.
I think I will count them again before I put on the cover if this doesnt sound right.
I didnt find a number stamped on the ring gear yet.
Old 01-02-2010, 07:03 PM   #6
nutsforchevys
I guess i need to learn how to count The front axle has 40 on ring and 13 on pinon that should equal 3.07.
Wonder why the teeth count are different on the front and back?
