T-5 Users, Shifter Help
Greetings,
We have purchased a T-5 for our 72'. So we could use some help in the shifter department. Knowing that the shifter will need to be longer that the S-10 style. What shifter works the best? Thanks, MrBlue
MrBlue 72' C-10 350 TKO-600 Current Project 54' Ford F-100 Life Long Project |
member #16
![]() Join Date: Dec 1999
Re: T-5 Users, Shifter Help
Heres a pretty good write up by brad on t-5's.
http://67-72chevytrucks.com/vboard/s...d.php?t=313954
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
![]() Join Date: May 2008
Use the S-10 tail shaft and top shifter plate. Then any Hurst shifter will be able to bolt to the shifter stub 2 hole.
Be very careful with the T-5. They are only rated 295 ftlb of torque and they are not kidding. I have torn up 3 T-5 with my 327 in a 68. If I had to do it over, I would save my money an buy the Tremec TKO 600 my 2 cents.
Mine is chopped, has a clutch, and a big block. |
you can build whatever type of hanhle you wish and just bolt it up to the tab
