Old 01-05-2010, 02:57 PM   #1
66coffin
66coffin's Avatar
Question '66 c20 to disc and keepin the 8 lug, help!
ok so i got a '66 c20 3/4 ton that i'm swappin '84 c20 discs to. got the spindles and rotors on but my problem is the tie rod ends for the 66 don't work (larger diameter) on the 84 spindles, my question to you good fellows is, should i change the whole center link with tie rods from the 84, which i don't have anymore or can i find an adj. sleeve that would make the transition i need? or any other solutions would be welcome, thanx guys!:
ps cant drive my darn truck till this is figgered out!! sucks!!
66coffin is offline   Reply With Quote
Old 01-05-2010, 03:18 PM   #2
62gmc910
62gmc910's Avatar
Re: '66 c20 to disc and keepin the 8 lug, help!
you will need the '73 up c20 center link and tie rods c10 may work not sure
Sleeving tapers is NOT safe
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 01-05-2010, 05:51 PM   #3
SCOTI
SCOTI's Avatar
I like the idea of using the OE 84 stuff. But, if you threw it away, you could machine a tie-rod sleeve w/the proper thread size on each end if you know a decent machine shop.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-06-2010, 01:13 AM   #4
Captainfab
60-66 Nut
I agree with 62gmc910
I would just find the steering linkage from a '73-'87 C20. I wouldn't think it would be too difficult to find.
