Old 01-06-2010, 04:31 PM   #1
67slammer
67slammer's Avatar
door panels
can you use 72 door panels on 67-71 doors? any help would be awsome. thanks mike
67 short bed stepside tach tilt buddy buckets bagged sittin on 20s and 4w disc brakes (not quite finnished)
67slammer is offline   Reply With Quote
Old 01-06-2010, 04:35 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: door panels
Yup, just need 72 window regulators to compensate for the thickness of the panel. You may need to drill several holes in the door for the plastic clips that hold the panel to the door.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 01-06-2010, 04:41 PM   #3
white 67
Re: door panels
Im not saying this is wrong but i put 72 door panels on my 67 and used my 67 regulators. It was i tight fit but they worked. I also had to put nuts in the door mount the arm rest. I think i just had to make the holes where the upper strip was bigger so i could fit clips in.
white 67 is offline   Reply With Quote
Old 01-06-2010, 07:07 PM   #4
4tiresngas
An American Soldier
4tiresngas's Avatar
Re: door panels
Yep,
I put 72's onmy old 69. I did not change regulators. It will work, but it's tight. Not too easy to get the handles back off, but it certainly is doable.
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
Old 01-07-2010, 07:27 PM   #5
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Re: door panels
Originally Posted by 4tiresngas View Post
Yep,
They work but there tight. Thats what i did. Not a great pic but you get the idea.
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 01-07-2010, 11:50 PM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
Re: door panels
here's mine - not a really good pic, but you can see enough.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 01-07-2010, 03:32 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Re: door panels
They won't work if you are planning on using the 72 woodgrain panels. Well, they probably will if you beat the handle on with a mallet and don't plan on removing it again
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 01-07-2010, 04:03 PM   #8
BossHogg69
motor exploder
BossHogg69's Avatar
Re: door panels
I also have '72 panels on my '69 doors - my grandfather did them when he restored the truck back in 1990-91. I have tried a few times to get the window crank handles off and I can't...
Adam
Old 01-08-2010, 02:02 AM   #9
QKENUF4U
QKENUF4U's Avatar
Re: door panels
the regs are cheap enough off here that theres really no reason to work harder instead of smarter.... i like the 72 panels way better than the early years.....
QKENUF4U is offline   Reply With Quote
