Old 01-26-2003, 08:04 PM   #1
mikep
Used to have a truck
mikep's Avatar
speedometer gear
I finished up installing the TH350 in my truck today with the exception of the driveshaft shortening which I have to wait until wednesday for. Anyway how do I figure out what gear I'll need in the transmission to get the speedometer to read right. I'm running 3.54 gears with 285/75-16 tires.
BTW that lokar shifter looks great !
No truck :-(
mikep is offline   Reply With Quote
Old 01-26-2003, 08:10 PM   #2
rustedchevy
go to google.com and type in speedometer recalibration or calibration words, youll come up with some pages of info on how to do this
rustedchevy is offline   Reply With Quote
Old 01-26-2003, 08:47 PM   #3
Sierra
A good site to check out is:
http://www.tciauto.com/tech_info/speedo_gears.htm
By the way, your tire diameter should be 32.83", so the only other factors in the equation are the number of teeth on the drive gear and the driven gear. It's simple to pull the driven gear housing and count the teeth, but you will most likely need to pull the tail housing to count the drive gear teeth. In any event, it is quite easy to pull the tail housing to count teeth and/or replace the drive gear. Good luck!
Sierra is offline   Reply With Quote
Old 01-26-2003, 08:50 PM   #4
Gee_Emm
Here are the best 2 sites out there.
http://members.core.com/~faldrich/speedo.htm
Gee_Emm is offline   Reply With Quote
