Dan
![]() Join Date: Dec 2009
LMC exhaust kit
Has anyone gotten this kit from LMC? http://www.lmctruck.com/icatalog/cb/full.aspx?Page=117 the one on the top of the page. It says it will bolt right up to stock exhaust manifolds, so will it bolt to my 90* ram horns? or does it only bolt to the 45* ram horns or does it bolt to the rear dump stock manifolds? Just curious if anyone knows. Thanks, Dan
1968 C10 Short Fleet - L79 327, th350 1971 Nova - 327, Th350, 3.73 posi 1971 K10 Short fleet - 350/350 1971 K20 longbox - 350, 4spd 1970 Chevelle, Tunnel ram set up 355, th350 1986 C30 Dually, 454/400 1967 Impala 4 door hardtop, Supernatural clone 1968 Camaro, 327, pwerglide 1967 camaro, numbers match 350, powerglide, bench seat car 1968 Nova, Numbers match 6cyl, powerglide 1968 Nova, 327, th350 1970 Impala, 350, Th350 1968 Impala, Numbers match 350, Th350 1971 Chevelle SS, Numbers match 350, muncie |
Dan
Re: LMC exhaust kit
i think ive figured it out. i didnt notice there was different kits for 2wd and 4wd. so the 4wd ones would be for the strait down 90* ram horns, and the 2wd kit would be for the angled back 45* ram horns.... so even though my truck is a 2wd im going to want the 4wd kit because i have 90* strait down ram horns. Right? i dont see why a 4wd kit wouldnt fit a 2wd being i have 4wd exhaust manifolds. feel free to chime in anyone
![]() Join Date: Feb 2009
Re: LMC exhaust kit
I think that the other thing of note would be that the 4x4 engine sits 2" further back in the engine compartment, which may lead to some unforeseen issues when it comes to routing the pipes.
-Scott 1972 Chevy K20 Picture Gallery Build Thread 1930 Chevy AD Picture Gallery 1929 Ford Model-A Picture Gallery 1975 Triumph TR-6 Picture Gallery |
Re: LMC exhaust kit
I installed the kit using the 45 degree rams and then, later, moved the engine back to the aft mounts and there was plenty of adjustment to make it fit properly. I am quite happy with the kit.
Re: LMC exhaust kit
I have the kit and love it. The fitment was great and US made. I bought the short-bed kit with OEM style outlets and cut it down to fit my Blazer.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
Dan
Re: LMC exhaust kit
the 4wd sitting back 2 inches more wont be a problem, ill have to cut the pipes a little shorter anyways because they are all made for long boxes, so ill compensate for the 2'' when i cut it back. so i think ill order the 4wd kit, unless anyone else can tell me a reason why it wont work? Thanks, Dan
Tags |
lmc exhaust 1968 |
