Motor Mounts
Are the motor mounts on a small block 2 WD the same as on a 4 WD?
Member #1049
Re: Motor Mounts
If you are refering to the rubber parts that mount on the engine block itself... Yes..
Re: Motor Mounts
I should have been more clear. I was talking about the metal part that bolts to the crossmember
Member #1049
Re: Motor Mounts
4X4's are different than a 2WD as they use an engine cradle that the rubber mount bolts too..
