01-12-2010, 06:00 PM | #1 |
LED bulbs
been thinking about upgrading some of the lighting in my 72 burb with LED's. not looking to go to a high dollar conversion, just use some replacement bulbs. figure i can change the running light bulbs. if i don't change all the directional bulbs i should be able to do without a resistor or whatever you have to wire in to account for the lower current draw and still have the flasher cycle on and off. i also need to change out a dead (left) blinker on the dash when i pull it to add the tach and vac gauges. especially in the dash, LED's should be a nice touch since they won't have to be replaced very often, and draw far less power. i have a stock alternator with external regulator (mechanical unit replaced with slim electronic one). oh....i see in the latest LMC catalog that they carry a clear modern style lens for the stock interior light and also an LED bulb for it.
if anyone has a line on part number for replacement bulbs or the places with the best prices....let the rest of us know....thanks! |
01-12-2010, 09:25 PM | #2 |
Re: LED bulbs
I've used www.v-leds.com before. They seem to have a pretty nice selection.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
01-12-2010, 09:32 PM | #3 |
Re: LED bulbs
So what is required (wiring, extra parts wise) if you want to change out to the LED style? Or can you just pop in the LED bulbs?
1972 Chevy C10 |
01-12-2010, 09:41 PM | #4 |
Re: LED bulbs
i re-did the lighting in my explorer with LED's i just bought 100 led's on ebay for $30 and wired them in, whether it was project board, or made bulbs. here are some pics. it was definitely worth it for me. better lighting and i learned alot.
01-12-2010, 09:42 PM | #5 |
Re: LED bulbs
whether you hardwire it in, or make a bulb like i did, as long as it has resistors for a 12v application, youre good, just get the positive and negative right, the resistors go on the positive end. most LED's on ebay come with free resistors.
if you want to buy them instead, superbrightleds.com has a good selection. if you want the brightest though go with the SMD ones. Last edited by energiesource; 01-12-2010 at 09:52 PM. |
01-12-2010, 09:46 PM | #6 |
Re: LED bulbs
There's somebody on here that makes them, But I can't rember his name
I'm not as good as I once was, But I'm as good once as I ever was. |
01-13-2010, 02:13 AM | #7 |
69 Fleetside
Re: LED bulbs
01-13-2010, 03:14 AM | #8 | |
Re: LED bulbs
You are correct big mike71...see LINK below For sale: Hand-Made Custom LED Brake and turn signal lights. http://67-72chevytrucks.com/vboard/s...&highlight=led
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 01-13-2010 at 03:14 AM. |
