Old 01-13-2010, 07:14 PM   #1
menace121978
menace121978's Avatar
lsx motor mounts!! for those waiting...
hey guys! great news... i just got an email from Phil at BRP. i'll paste it...
The A/C compressor on most cars and truck LS motors will clear the F-body Lines(rear exist) may need clocking/bent or cut and welded back to clear, the sanden 508 will clear also but you may have to use a cut off wheel and zap off two mounting tabs that are not used,also use the side exit or 90 degree and 120 degree exit lines if rear exit is used, with side exist most stock truck exits are on the passanger side clears. If You guys buy this month you will get the 09 Jobber cost of only 469.00 with crossmember and trans mount and hardware 499.00 for 1 ¾” Mid Length hedders, and 669.00 for the 1 ¾” Long Tube this month. Tks Phil LH-8 Oil pan is flush with K-member and the hedders and pan clears and you can bag the truck and put on ground.Tks Phil
Sent: Tuesday, January 12, 2010 9:49 AM
To: info@brphotrods.com
Subject: mounts
hey, my names Dennis Dean and i contacted you guys in November and December about your mounts working in '73-87 chevy trucks. i have 4-5 guys wanting to buy your kit (67-72chevytrucks.com) along with myself but we NEED to know if the factory a/c compressor and lines will clear the passenger side frame rail without notching it. We understand your mounts raise the motor and tranny up but dont have any info on if the compressor clears. please give me a call or email back so i can move forward with my frame off and you can sell a few of these kits. thank you, Dennis Dean
now by going this route it is a little more pricey. but some of us have the 3 covers that go over the coils and intake so a top mount a/c compressor isnt the 1st choice. and i've said it before by the time you spend money on the poly mounts, a/c bracket, and compressor you'll be in that range already. so this is killing a few birds with one stone per say... and you wont have to deal with modding the rear crossmember if your running the 4l80e, or worry about pinion angle. i can order my mounts and headers now!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 01-14-2010, 12:03 AM   #2
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Re: lsx motor mounts!! for those waiting...
Info on an interesting possibility in a few days. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 01-14-2010, 09:06 AM   #3
menace121978
details!
ya, any info we can all get together will help others doing this swap. (i hope) or at least give a few more options...
"Dennis the Menace"
Old 01-14-2010, 09:14 AM   #4
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Thats awesome Dennis! Thanks for clearing things up for everyone. What is the rear crossmember mod for the 4l80 you are speaking of? Just curious. Thanks again--Josh
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 01-14-2010, 09:30 AM   #5
menace121978
pcmcobra had to get an ear type piece welded onto his factory crossmember because the 80e is longer than the 60e/700r. you can only slide it back so far because the bend in the frame rail. (keep in mind i dont recall the type of engine mounts he used)
"Dennis the Menace"
Old 01-14-2010, 10:06 AM   #6
STOCKISH
STOCKISH's Avatar
OK, thats cool, I dont mind having to fab a crossmember for the trans. Thanks for all your help.
--Josh
