how low can i go?
im in the middle of building a 70 short fleet with a turbo charged ls1. i like the looks of a bagged truck but was told i will never get all the power to the ground as if i did a static drop. is this true? can someone post pics of the lowest static drop there is with 20's all around thanks
A guy with a truck
Re: how low can i go?
Bags can be properly set up to handle as well as coils. Unless you're making a large amount of power and trying to drag race, which I assume you're not- based on the 20s, you will have no problems. You can do a static 5/7 or 6/8 drop and be plenty low enough and not have to worry about the extras that come with bagging. All depends on what you wanna do...
Check out user Raguemo- he has a white '67 dropped 5/7 on 20s...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 01-14-2010 at 12:03 AM. |
THE TOY STORE
bags are just springs that are adjustable. nothing more nothing less. aplying power to the ground will all be based on your suspention (2 link 3 link 4 link) and shock setup.
having a badass truck and not driving it is like having a playboy model as a wife and not..... well you know. |
any pics?
#5 | |
3DrDwn--the 'burb not the band
Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 ![]() duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
![]() Join Date: Sep 2002
