Old 01-15-2010, 09:40 AM   #1
robby5323
I need some tail light wiring help, please....
Working on the project - 1965 SWB Fleetside. I am trying to get the tail lights working with blinkers, brake lights, etc... Over the years, someone did a hack job on the rear taillight harness and there are splices of different wire everywhere. Here is what I have at the plug for the harness:
1. Black/Yellow wire lead
2. Black lead
3. Dark Green lead
4. Yellow lead
Can anyone tell me where or how each lead needs to go...? I was able to play around with it a little yesterday and got the brake lights, running lights, and signal lights working UNTIL you turn on the headlights, then the blinkers just hold and do not blink. The plug has had the wires spliced off with only about 3 or 4 inches on them, so the original wire colors are all gone...
Appreciate any help...
robby5323 is offline   Reply With Quote
Old 01-15-2010, 10:11 AM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: I need some tail light wiring help, please....
I use a trailer wiring harness to clean things up...go back to someplace the harnesss is clean the take your time and spice in the new wire..the colors will even match up...I'm not going to guess what colors go where ( I'm having CRS right now) but on the box it will tell you everything its standard
hope this helps
http://67-72chevytrucks.com/vboard/s...d.php?t=185856
heres a diagram for our trucks you can follow
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 01-15-2010, 11:18 AM   #3
4dranch
Shloooooong bed member #2
4dranch's Avatar
I went through the same thing with my tail lights and would get it figured out and they would work for a little while then go out. I got tired of chasing the gremlins and broke down and got both front and rear tail light harnesses. the best $70.00 bucks I ever spent.
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 01-15-2010, 11:58 AM   #4
robby5323
I looked in the LMC catalog and they say a 4 to 6 week wait on a harness. Any other recommended places I might be able to pic a harness up...?
Old 01-15-2010, 12:09 PM   #5
4dranch
4dranch's Avatar
Here's where I got mine from. fast shippers also. here's a link to their page.
Part numbers 52-623 and 52-662 hope this helps.
http://www.classicparts.com/Wiring-H...oducts/205/3/0
David,
Daughters 66 truck:
Old 01-16-2010, 11:35 PM   #6
LILRED66
LILRED66's Avatar
Try here:
www.bowtiebits.com
www.oldchevytrucks.com
www.truckandcarshop.com
I have purchased wiring harnesses from LMC Truck on several occassions, over the counter, without waiting for backordering.
LILRED66 is offline   Reply With Quote
Old 01-15-2010, 12:00 PM   #7
63 & 64 Bowties
and a few others
Does this help at all? I have a pdf I can email you if you can't read this one.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 01-15-2010, 12:07 PM   #8
DaddyMack
Wide Eyed User
DaddyMack's Avatar
I would only add that MAKE SURE you have a great ground. If one ground does not have a good connection, it messes with the entire system. Check them all, and be sure your tail light areas are not painted over where the housings touch the body.
1962 Chevy P/U SB Fleetside
350/350
2.5/5 static drop
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723
Final (as final can be ) Pics: http://67-72chevytrucks.com/vboard/s...d.php?t=393441
DaddyMack is offline   Reply With Quote
Old 01-15-2010, 12:12 PM   #9
robby5323
Thanks for the schematic... I will print if off and see if I can make sense of this. It looks like I have the yellow and green wires, but the brown wires are black and black/ yellow on the plug that is being used. Maybe a different plug-harness than the stock one has been put in. I will try to wire it up and use the black and black/yellow wire as browns per the schematic and see what happens.
Old 01-15-2010, 01:21 PM   #10
62gmc910
62gmc910's Avatar
YeLlow is left turn
gReen is right turn
Brown or black is park /tail
the other one is prolly back up lights usually lt green
these are the SAE /stock rear light colors using them make later trouble shooting easier
As posted above sounds like a ground issue
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 01-16-2010, 08:47 PM   #11
robby5323
Got all the wires traced out today, found were each was supposed to go and was able to get it working correctly. It is true that good grounds are very important on this type of system. I found that the lights were just a little dim just using the buckets as a ground themselves. So, I ran additional wire connected to each bucket screw and made one good, solid connection on the frame. Brightened up the bulbs considerably. Thanks to all for the help. She'll be up and running soon. Pics to follow...
Old 01-17-2010, 02:38 AM   #12
markeb01
Senior Enthusiast
markeb01's Avatar
The short answer is yes. The ground side must be just as efficient as the power side or the device will not operate at full capacity. Grounding all the lamp buckets with wire to a common ground, instead of relying on brackets (which may be loose, rusty, or painted) will eliminate many random electrical problems in the future.
Old 11-05-2011, 07:45 PM   #13
Turkey
Turkey's Avatar
I just received the wiring harness (from classic parts) from the firewall to the rear for my tail lights and noticed that there is a 3 prong plug that plugs into the firewall and a single that I don't have a plug for. Is the single a ground?
Turkey is offline   Reply With Quote
Old 11-06-2011, 12:14 AM   #14
protrash64
Resistance is Futile
protrash64's Avatar
Nothing is grounded in the harness, only at the light buckets. You should only need three wires to operate the taillights. Left, right, and brake. The extra wire may be for back-up lights if you have them. The only other wire is a short pigtail off the drivers side tail that is for the license plate; connected to the running lights.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-06-2011, 09:16 AM   #15
ChevySixty6
ChevySixty6's Avatar
I'm sure that wire is for your backup lights, if you have them.
Members i've met: LiLRed66
ChevySixty6 is offline   Reply With Quote
Old 11-06-2011, 12:11 PM   #16
kieth
kieth's Avatar
I added a grounding block to the rear and front of my gmc, soldered a ground wire to every light housing then grounded it to the block. Bright lights no mysterious dim light............and then searching around for a good ground. It is worth the time and the money. Kieth
kieth is offline   Reply With Quote
Old 03-24-2020, 02:52 PM   #17
lowroder
Attachment 824272
Are the tail light buckets aluminum or stainless.? just curious how to solder on them
lowroder is offline   Reply With Quote
Old 11-06-2011, 07:23 PM   #18
Turkey
Turkey's Avatar
thanks for the info guys.....I'll see what happens when I get the battery hooked up.
Old 01-17-2012, 05:26 PM   #19
Rafael505
Rafael505's Avatar
I have some prob on mine and I have check and ground my light housings still have issues but what I did notest was my steering wheel, I replaced the wiring harness and notest when I tighten the bolt I had no break light not working or when I loosened it my right signals didn't work or one side was briter then the other,, I dont know, i ordered a new tail light harness and go from there again lol
Check out my Photos
http://67-72chevytrucks.com/gallery/...ry.php?cat=769
L.L. N.M.
63 chevy c-10
67 chevy c-10
71 chevy Blazer 4x4
Rafael505 is offline   Reply With Quote
Old 03-18-2020, 08:05 PM   #20
lowroder
I know this is a very old thread...but seems to be maybe a issue we all can have,
I have a 62 C10 I recently purchased.
previous owner had installed new LED hood markers an taillights.
Hood markers are good n bright an work as should. However the taillights had worked when purchased but the driver side was a bit dimmer. figured ground but hadn't got to check.
i had been wanting to work on a headlight issue he told me of being the headlamps were very dim an drivers was bright an passenger barely illuminated.
so... when i went to pull the truck outside i noticed i hadn't seen my brake lights light up as i pulled from the garage.
i turned my headlights switch on an surprise i had NO taillights /brake lights or rear turn signals.
So... i checked fuse...GOOD.
Checked wire connections GOOD
However not sure if i have power yet as im still diagnosing this. Need Some Guidance
So Where do i start at ...when it worked fine before..
Could A Faulty Headlight switch be Causing all my issues? with faulty headlights an now NO rear lights at all???
Old 03-23-2020, 11:37 PM   #21
rustyrodknocker
As is often the case with this old stuff. You may be chasing multiple faults. However your brake lights are independent of the head light switch. They do run through the turn signal switch. I always check power up the column and back.
The switch is like the central nervous system of indicator lights.
rustyrodknocker is offline   Reply With Quote
Old 03-24-2020, 12:43 AM   #22
franken
Time to get a voltmeter (DVM), wiring diagram and work on understanding how things work. Voltage is typically measured to ground with everything connected.
Learn Ohm's Law (simple) and the relationships between coltage, current and resistance.
Turn/brake lights are different filaments than running lights. Always keep in mind that the exact same current that flows into a load from the battery/alt has to flow back to the source via the ground. One of the headache reducing things to do would be go through and fix all the grounds.
https://www.google.com/search?client...wiring+diagram
