Shlong Bed Club
how big?
how deep of a notch can be used until the trailing arms contact the frame? a simple c-notch or a full on step?
![]() Join Date: Sep 2002
Re: how big?
Here's my C-notch with a picture of the trailing arm to frame clearance.
I also flipped my crossmember, so that moves the arms a little more closer to the frame. At full dump, I have a bit under 1/2" clearance. Of course, with the track bar adjusted to center the rearend at my anticipated ride height, it has more clearance on one side than the other when dumped. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: how big?
Are you putting the bag in the stock spring location?
You can gain a little more drop if you move the bags to the axle. You can also use a 2" or 3" block if your wheel diameter is bigger than 15". |
