01-23-2010, 07:07 AM | #1 |
few questions from a newby
Couple months ago I purchased a 65 chevy fleetside lwb for my son and me to work on. He is ten now and I figure I've got 6-7 yrs to before he can drive so we are going to take our time and hopefullly he can learn a thing or two about these old trucks.
Well I got my truck home and started doing a little digging into what I had. Turns out that it is a 65 chevy c20 custom camper with factory in dash a/c, automatic, originally had a 327, bbw, custom comfort package. I believe it has all the trim that could of been added. It is still the original marroon color. It has the foot step in the side of the bed, it still has the camper tie down hooks on the side of the bed, and it also had two lights on top of the cab. Is there alot of these around? When doing a search very few 65 custom campers come up and the ones that do don't have factory automatic,in dash air, etc. I would hate to modify to much if it is something they did not make many of. I have taken it completely down to the frame. The body is waiting for sandblasting. I am working on the suspension and frame now tearing it down and rebuilding. Here is where I am a little confused and maybe someone can help. The PO had changed the truck over to 5 lug with disc brakes up front. He has also lowered it. It looks as if he cut the springs up front and maybe heated the rear and put lowering blocks on it. The front upper a arms are pointing up in the air and I would like to fix this while I am rebuilding the suspension. My question is how far did the PO modify the front. I would like to get suspension parts but I don't know what to order year to order them for. I know a 73-87 parts will bolt up but will 1/2 ton 73-87 parts bolt up to the 65 3/4 ton stuff. I can assume that since it is 5 lug disc and the front bearing is a timken m12649 that the spindle was changed out. How do I know if thats as far as he went. Would he had to of changed the a arms to because of the different ball joints between 1/2 and 3/4 ton? I am trying to figure out do I order springs for 65 3/4 ton or later model suspension and does it matter. Also as for dropped spindles I assume I just order 73-87 ones. And what ball joints do I need? The crossmember is bolted on to the frame. Are they originally riveted to the frame and this maybe a clue that he did a whole crossmember swap? Here some numbers I found on the various parts Brakes fdp03fe front outer bearing timken m12649 Rotors 210404 c thk 965 spindle 75589402 rh cfd 2 72 gm and 15589401 lh cfd 1 93 gm upper a arm 3786 lower ball joint 6m1 9740977 Dont know if they help but maybe someone will have a clue. |
01-23-2010, 09:20 AM | #2 |
Re: few questions from a newby
Let me be the first to say . Sounds like an interesting project. You might find these links interesting:
http://67-72chevytrucks.com/vboard/s...ghlight=camper http://67-72chevytrucks.com/vboard/s...ghlight=camper As far as identifying what has been modified you need to post up some pictures... A picture is worth a thousand words, as they say. |
01-23-2010, 10:41 AM | #3 |
Welcome Sounds like you found a pretty rare truck Cool to hear about the father son build plans
Post pics and maybe start a build thread
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) |
01-23-2010, 11:22 AM | #4 |
Here some pics of when I bought the truck.
I have more pics at home of the tear down. I will try and post some of the crossmember and suspension. I will also probably start a build thread since I am taking lots of pics. |
01-23-2010, 11:27 AM | #5 |
Resistance is Futile
Sounds to me like the PO ditched the 3/4 suspension and went 1/2 ton. Pretty common and a better option for customizing/wheels/etc. IMO. It had the 8-lug set-up before.
Thats a well optioned truck and looks cool to me. Looking forward to more pics of your project. from AZ.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
01-23-2010, 01:02 PM | #6 |
60-66 Nut
Welcome to the Forum
As already mentioned,a picture is worth a thousand words. To answer a couple of your questions, the front suspension crossmembers were originally bolted to the frames. As for the springs you should be able to use springs for a '73-'87 C10. Of course we need to actually see what you have to make a firm recommendation.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 01-23-2010 at 01:02 PM. |
01-24-2010, 03:30 AM | #7 |
Welcome to the forums from Kansas City, KS. Post your VIN and it can be decoded.
Good luck with your project and it is a low production model truck, that is well-optioned. Please keep us posted with pictures of your progress. |
01-24-2010, 07:20 AM | #8 |
I got a few pictures of the suspension.
Here is the rear suspension As far as I know it definitely is a later model year because of the 5 lug. Date stamp shows E117 which is probably 1977 or 1987. I haven't figure out what the ratio is yet. Does it look like the coils in the rear have been heated? I am going to start a build thread with pictures and progress later today. |
01-24-2010, 12:41 PM | #9 |
One foot in front of the other
Welcome to the site.
01-24-2010, 09:46 PM | #10 |
LILRED66 here is the vin number c2545b134770
01-25-2010, 02:05 AM | #11 |
60-66 Nut
From what I can see of the front suspension, I'd say it is original or at least older C10 style, except for the disc's it has.....can't see the spindles or rotors.
In the rear, I'd say that the differential is likely a '73-'87 since it still has the leaf spring pad on it. And yeah those springs have been heated.....they're junk IMO. Someone didn't take much pride in doing a nice job on that rear swap.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 01-25-2010 at 02:05 AM. |
01-25-2010, 10:27 AM | #12 |
If you could pull a front wheel and get some shots of the rotor and knuckle as well as how the pan hard is mounted in the rear .... The rear drop blocks need to have tubing in the bolt holes to carry the bolt load instead of squishing
01-25-2010, 06:35 PM | #13 |
Here is the front suspension
[img] Anyone have a clue of how far back it the PO replaced? And if he replaced the spindle would the 3/4 ton a arm work with the later model spindle? |
01-25-2010, 08:34 PM | #14 |
He definitely replaced the spindles as they are disc('71+). The control arms appear to still have the older style bushings so they are original or '63-'66 1/2 tons. I thought that 3/4 ton arms would not work with '73+ balljoints, but I may be wrong. Others may know for sure.
01-26-2010, 02:07 AM | #15 |
60-66 Nut
Going by the style of the caliper mount those spindles and rotors are the '88-'98 parts. The control arms are of the '63-'72 C10 and C20 style. I'm going to guess that the lower control arm is the C20 piece since the spindles are of the '88-'98 vintage. One way to verify the newer rotors is the studs will be 14mm instead of 1/2"-20.....those lug nuts look metric to me.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 01-26-2010 at 02:11 AM. |
01-26-2010, 12:48 AM | #16 |
They have a vin decoder on this site http://www.americanclassic.com/ But it wasn't working when I tried it.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
01-26-2010, 06:35 PM | #17 |
LMC has a chassis chart
C= 2WD 25= 3/4 TON LONG BED 127" WB 4= PICK UP TRUCK\ 5= MODEL YEAR 1965 B= ASSEMBALY PLANT BALTIMORE http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=8
01-26-2010, 07:21 PM | #18 |
Cool, I almost bought that truck, but didn't have anywhere to store it at the time. I'm pretty sure the PO told me he just rigged up the suspension to get it low. You might be better off starting over so you know what you have. It's a good start though. Looking forward to seeing your progress.
01-28-2010, 01:35 AM | #19 |
One other item I was curious about. This truck has a place for two lights on top of the cab, one on either side. The look like they were teardropped shape. Any one have picture of a truck with these. Thinking of replacing if I can find a place that sells them. Might have to retro fit some.
