Old 01-23-2010, 12:38 PM   #1
57larry
Bellhousing question
would a 61 bellhousing be the same as one from a 66 as far as does it have the same bellhousing side mounts and does it bolt to the block the same number of holes / thanks
57larry is offline   Reply With Quote
Old 01-23-2010, 12:52 PM   #2
Captainfab
60-66 Nut
Re: Bellhousing question
It will bolt to the crossmember the same, but it depends on which engine the '61 bellhousing was originally bolted to. If it was bolted to a 235, then it will not bolt to any other engine. And the same if it was bolted to the GMC V6. If it was bolted to a 230, 283, or 327 then it will bolt to any other I6 or GenI small block or Mark IV or V big block.
Another thing to consider is that the '61 bellhousing would be setup for a hydraulic clutch.
Old 01-23-2010, 01:19 PM   #3
62gmc910
62gmc910's Avatar
And for extra fun some of the hyd clutch bells were right hand clutch openning some may also have the top hole drilled 68 ??up had a bigger trans hole for the SM465
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 01-23-2010, 01:36 PM   #4
57larry
WOW! a lot of info here. I'm looking for then a bellhousing with a 4 5/8 hole that will mount to a 72 V8 block but has transmision mounts. Right? thanks, Larry
Old 01-23-2010, 03:34 PM   #5
padresag
why not just say what you want to do. be a little more specific and you should get a more specific answer. what is it in and what do you want to do?
ron
padresag is offline   Reply With Quote
Old 01-23-2010, 04:51 PM   #6
57larry
ok, I have a 72 v8 and want to install a saganaw or muncie 4 speed. I need a bellhosusing with a 4 5/8 hole and trans mounts. What years fit?
