01-24-2010, 10:41 PM | #1 |
People know me
body mount bushings
So anyone have a source for a cheap set?
This will be a daily driver so anyone have actual real life opinion on these? I have never owned a rig with poly bushings before. I have heard they squeek, ride rough etc, and I have also heard they are the best thing ever.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
01-24-2010, 10:56 PM | #2 |
Grandpa in the rustmobile...
Re: body mount bushings
free bump which bushing should you go with?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
01-25-2010, 12:06 AM | #3 |
I have poly bushings on my longhorn, & will say that they are a little harsher,but no issue with squeaks. If you do any 4 wheelin, you may want to stick with rubber ,as they flex a bit & may help not to rip up your tin. crazyAL
http://community.webshots.com/user/hotrodhorn |
01-25-2010, 12:32 AM | #4 |
Got my poly mounts from brothers. I have poly motor mounts too. If i had to do it all over again, i'd probably go with rubber cab/radiator support mounts. I have a mildly built small block, somewhere between 320 and 350 hp. Whole truck vibrates at idle, i feel every bump in the road, and i have about the same amount of rattles as when was stock. I blame the poly bushings at least partially for all of that. But hey, supposedly i'll never have to change them.
01-25-2010, 11:13 AM | #5 |
whats diff. between rubber poly and rubber why go rubber vs poly or vica versa, does poly last longer or what?
01-25-2010, 11:27 AM | #6 |
Here are some past posts that might be of interest...
http://67-72chevytrucks.com/vboard/s...d.php?t=374367 http://67-72chevytrucks.com/vboard/s...d.php?t=192342 http://67-72chevytrucks.com/vboard/s....php?p=3701630
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-25-2010, 11:34 AM | #7 |
I went poly under the cab on my longhorn, due to a steel tilt front clip. Without the front fenders/rad support tying the cab to the frame, the 4 rubber bushings under the cab moved around too much& I didnt have a clutch that letup in the same spot every time! The poly mounts are much stiffer, & took care of that issue. While it is a little harsher on the ride, I dont feel its an issue. I also have poly eng & trans mounts, & feel that they added more to vibration (@ idle), than the body mounts did. crazyAL
01-25-2010, 11:41 AM | #8 |
double post,please remove. Thanks,crazyAL
http://community.webshots.com/user/hotrodhorn Last edited by 69 longhorn; 01-25-2010 at 12:13 PM. Reason: remove, due to double posting |
