help
i lowered my truck on sunday, now i need so do the wheel alliignment, all i have to do is remove or add the shims right?, and then one wheel is more inward than the other any help?
1986 gmc sierra....http://67-72chevytrucks.com/vboard/a...hp?albumid=622 |
Re: help
If you didn't mess with your steering linkage then you should only need to add an EQUAL spacing to both bolts on either side. You need to find the alignment specs for your car. You can align it with a plumb-bob and a protractor... and google will probably help you out with a general DIY-alignment how-to. If you are just trying to get it good enough to drive to the alignment shop, just get it fairly straight up and down and call it a day... I think only incorrect toe-in will cause excessive tire wear for a short distance.
1968 LWB C20 / AC / Wood Bed Last edited by crakarjax; 01-26-2010 at 11:17 AM. |
