Will 71-72 5 lug axles work in 70 rearend???
I'm wanting to convert my rearend to 5 lug. The rearend in my 70 is the wide version. My Q is will 5 lug axles out of a 71 or 72 fit without modification. I found a good deal on a 5 hole coil rear. My rear is a 3.73 posi, thats why I just want to swap axle shafts. Also will the Drums off the 71/72 fit once I change the shafts. Thanks for the input.
1970 SWB Build |
Grandpa in the rustmobile...
Re: Will 71-72 5 lug axles work in 70 rearend???
I think everything you stated is true I THINK
you can order new axles from ECE for under 300$
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
![]() Join Date: Apr 2005
Yes and yes...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Thanks for the replies. Found this rearend out of a 72 that the guy is parting out(Blown Motor). Its a 3.08 open he thinks. He said he'd take 50 bucks for it. I pulled the drums off and they dont look worn much at all. He thought they were replaced a couple of years ago. I figured its worth the $ for the drums alone. Looks like i'll be picking it up sat.
1970 SWB Build |
what should I look for in a rearend? going to look at a 5 lug coil from a 402BB tomorow..
ECE does indeed have 5 lug 30 spline axles for 63-72 12 bolt rears...$279.00/pair. If you're already running a 3.73 posi thats a great combo...later, when you get tired of drum brake fade, the rear calipers from a late 70's cadillac seville will fit your housing, and they have the emergency brake built into them... CPP has the rotors and caliper brackets which will fit those new 5 lug axles.
Another plus is you'll be running a standard 5x5 lug pattern; everybody and his brother sells wheels that will fit that setup!. |
#7 | |
Like a Rock!
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() |
Like a Rock!
One more question on this subject, not to hijack- can he use any axles from later years like 73' and up??
