![]() Join Date: Jan 2010
Air bags ?
Can you use air bags like the old air shocks? Maybe just run an valve for each bag under truck and put air in them. Once you establish the ride height just leave them alone. Not to familiar with bags so don't know if the tanks and compressor maintains the air in them. Only want about a 4/6 drop but was hoping to get a decent ride also.
Thanks Coater. |
Redefining LowBudget
Re: Air bags ?
yep use a scrader valve on each bag....if your going to do just that I would think a set of drop springs would be the ticket
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
Re: Air bags ?
Thanks Hottrucks! I need to do some research. I was going to use drop spindals and a flip kit for the rear and use the airbags for the ride.
Re: Air bags ?
Ride Tech offers an AOL set-up (air over leaf). You install the flip kit & then remove some of the leafs using the air bags to restore the capacity @ ride height.
Re: Air bags ?
What about the front?
Re: Air bags ?
Same thing (although the front is more critical to maintain air pressures for alignment purposes).
Happy to be here
![]() Join Date: Mar 2000
Re: Air bags ?
What year truck? Leaf or coil rear?
Re: Air bags ?
It's '85 Silverado.It has leaf springs.
Re: Air bags ?
I'd recommend finding a good place that does Lifetime Allignments.. My Dakota eats ball joints like appitizers, so I chose to go to Firestone to get a Lifetime Allignment for $150.. Worth every penny after 3 allignments.. Once snow is gone I need another one since I just changed ball joints.. And yes, you get it alligned at your ride height.
[CENTER][FONT="Arial Black"]-------------------- Joey Dubs -------------------- 2000 Dakota - Bagged, Shaved, and more 2003 Ram - Fast, and perdy 1951 GMC Stepside - All apart, like a puzzle. |
