Old 02-01-2010, 03:00 AM   #1
slick78
Rear airbag setup
I got a question. I got a 1978 c10 stepside and im doing my suspension. I already did the front now to the rear . The rear is alreay lowered thats how it came when i got it. They took out leafspring and just left the long one and the little one. I wana put bag on the rear tho. What would be a good setup? I have heard of the air over leaf setup, is that ok? What would u guys recommend? And if i put airbags, do i have to add leafsprings?one ladt quedtion sorry. Does anyone know how many inches is lowered the way its setup now? Please help!!! Thanx
slick78 is offline   Reply With Quote
Old 02-01-2010, 03:19 AM   #2
thrtsxchambers
thrtsxchambers's Avatar
Re: Rear airbag setup
How far do you want the rear to drop, do you want the truck to lay frame or just be adjustable? I have done the bag on leaf but don't think it will drop all the way down. Let us know your goal for the height and then you will get opinions more suited for you goal. I have 4link cantilever on the rear of my 83 and my truck will lay on the frame which also requires a step notch and cut the bed floor or raise the bed floor.
thrtsxchambers is offline   Reply With Quote
Old 02-01-2010, 03:26 AM   #3
slick78
I dont want to lay frame. Just adjustable so i can set it to a hood hight. Nothing to crazy.
Old 02-01-2010, 09:36 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
I ran an AOL system in my 77 Cheyenne for several years and it worked great. I do recommend that you run a longer second leaf. In my system we ran the stock top and second leaf. What you have has the potential to warp or bend the top leaf.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-01-2010, 09:38 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
More
Articles-
"Refining Sierra"
Old 02-01-2010, 11:13 AM   #6
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I am considering a kit like this, and it looks like it could work for you. Does anyone have any experience with it?
http://www.jegs.com/i/Air+Lift/022/59103/10002/-1
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 02-01-2010, 11:38 AM   #7
slick78
N2trux i like that setup.now that i remember i seen pics before. What kit do u have? How much did ur setup run u? And u said to add one mre leaf too, so i would have threr in all correct? Will that be safe?
Old 02-01-2010, 12:36 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Slonaker View Post
I am considering a kit like this, and it looks like it could work for you. Does anyone have any experience with it...Slonaker
No that will not work. The bags are "helper" bags and do not have enough travel to lift the rear properly.
Originally Posted by slick78 View Post
....What kit do u have? How much did ur setup run u? And u said to add one more leaf too, so i would have three in all correct? Will that be safe?
I used the Ride Tech AOL kit. LINK If you look at the last pic of my system note that it has the top tow long leafs. You need these two rather than a long and short one. I ran my system like that for several years and it worked great.
Articles-
"Refining Sierra"
Old 02-01-2010, 12:53 PM   #9
Slonaker
Slonaker's Avatar
You are assuming he wants adjustable height air bag rear suspension. Since he said the truck is "already lowered," I assumed he was keeping it there and wanting to add helper bags.
Slonaker
Stock '01 Silverado
Old 02-01-2010, 01:13 PM   #10
thrtsxchambers
The post says the front is bagged and the rear is lowered and now want to bag the rear. Looks like the kit n2trux has will work, nice setup. What did you do to your rear leaf bracket?
Old 02-01-2010, 01:50 PM   #11
slick78
So i visited the link u put. Now which one should i use? Theres different ones. And what if any modifications would i have to do? Do i have to c notch. Sorry to ask so much questions i just wana make sure to do it right.
Old 02-01-2010, 04:40 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
My file shows I used an #ARK3004 Rear over leaf kit. Give Ride Tech a call and ask for Tony.
It doesn't shw in the pics, but we also added a 2" block. With that combo it would set the pumpkin right on the bed floor. We added a button bump stop and it gave about an inch of clearence.
I recommend you do a mild C-notch. Pull the bed and do it all at one time.
Articles-
"Refining Sierra"
Old 02-01-2010, 11:28 PM   #13
slick78
So u added blocks. Did u add shackles or anything else. How do i know how much c notch to do? I like ur setup and thinkng of going with it
Old 02-02-2010, 12:21 AM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes, I used shackles as well. You can buy a bolt in notch or build your own if you have the skills.
Articles-
"Refining Sierra"
Old 02-02-2010, 07:46 AM   #15
andrewmp6
Ridetech sells a bolt in 4 link that will get it low but not lay frame and you don't have to cut the bed.
Old 02-02-2010, 06:33 PM   #16
slick78
well im kinda in a budget so i think the aol system is would work better for my wallet and my truck.the other kit is like $2000.
Old 02-02-2010, 06:34 PM   #17
slick78
hey n2trux,what size gallongs u use? and compressors?
