Old 01-29-2003, 07:42 PM   #1
rayville body
need help with 68 grille
i started shaving the bowtie off my 68 grille today and ran into a problem. i have to remove the inner part of the grille to finish the weld properly. the piece is on there with bradds and i was wondering if i should weld it back on or use some kind of glue. the glue would also seal the gap between the two pieces. the grille trim will hold it on but i want the extra security. any advice will be very much appreciated.
rayville body is offline   Reply With Quote
Old 01-29-2003, 09:38 PM   #2
Vince M
Vince M's Avatar
If I understand what you said correctly...mine is riveted on and works good. When I reassemble it I'm going to rerivet it...now I'm starting to sound like a frog..
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 01-29-2003, 09:46 PM   #3
72MARIO
72MARIO's Avatar
I dont really understand what are bradds? There is a grill moulding clip set you can buy new. Do you have any pics? I am also going to remove the bowtie from my 67 grill, I was just going to cut out the area where it jumps out a little bit for the bowtie sits and weld a patch following the rest of the line make sence? Kinda remove the square area that flat . hope I helped or can help. later Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-29-2003, 09:47 PM   #4
72MARIO
72MARIO's Avatar
I get it your talking about the rivets. Rivet Rivet .....
2005 TAHOE DD
