Rear disc kit & front rotor's score!!!!!!!!!!!!!
Bought this SSBC rear disc kit with about 400 miles in it and a brand new set of cross drilled front rotor's for $200.00 on Saturday!!!!!!!!!!!
Re: Rear disc kit & front rotor's score!!!!!!!!!!!!!
give you $201.00
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
$201.50!!!!!!!!!!!!!!!!!!!!!!!!!!!!
BAD BOW-Silverado XST
$250.01
why is it everyone always finds these deals but me?
1987 350 TBI lowered 5/7 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Hope your truck's a 3/4 or 1 ton. 1 too many lug holes for a 1/2 ton.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Last time I checked 3\4 and 1tons were 8-lug, I think he will be ok with a K10...
#8 | |
#9 | |
![]() Join Date: Mar 2005
Update: I just noticed that you got the SSBC rear calipers. Not sure if they require the E-brake like the Caddy calipers do. For $200, you got a killer deal! Last edited by chevyrestoguy; 02-04-2010 at 10:32 AM. |
#10 | |
Thanks. Thats good info about the E brake. Some early Chevrolet vehicles have an external residual pressure valve that screws into the master cylinder and the line hooks into it. Later models have this valve internally. With that said the external kind you can drill out the valve and reuse otherwise you must get a new one.
1972 K5 CST. Work in progress. 408CI 1980 K10 |
Hey raveer2000,Thanks a bunch for the info!!Any idea what model and or year chevrolet's have this external residual pressure valve that screws into the master cylinder????Thanks!!!!!!!!!!
Chevys Kick A$$
Hey damn nice score for sure
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
Yea,there going on a k10 6 lugger!!!!!!
Will you have to change the proportioning valve to run rear discs? I've read both yea/nea on this.
#15 |
The guy I bought it from did change it,He said he had problems bleeding the brakes and bought one from Jegs,I also got the proportioning valve to,But I was going to put an ajustable one in the rear insted of changing the one in the front because it's alittle hard to get to!!!!!I have to do some research to see which one is best.
#16 |
You will also need a new master cylinder. The old master cylinder has a residual pressure check valve built into it. If you leave the old master cylinder on there will be approx 10 to 15 PSI left in the brakes to the rear. Normally on drums this keeps the wheel cylinders from leaking. But on a disc setup this small amount of pressure will cause the caliper to drag and overheat and wear the pads rapidly. Many people don't change this when converting to 4 discs and don't understand why the rears keep wearing out so quick.
#17 |
And good luck with the parking brake on them.
#18 |
From What year truck will I need a master cylinder from?
