02-03-2010, 08:48 PM | #1 |
power lock problems
I have a 83 GMC with power locks. when you hit the unlock button they unlock,but will not lock. any help on this issue would be greatly appreciated.
http://www.gulftruckinc.com |
02-03-2010, 08:56 PM | #2 |
Next project: 1970 K10
Re: power lock problems
Could be the lock relay, it's mounted above the gas pedal. But I would start at the drivers door switch and work back.
Check all the connections at the switch. Check the connector under the dash near the kick panel running from the door to the inside of the cab. Wiggle that harness while trying to lock it. My windows were working intermittently for a while, and that's where I found my problem.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
02-03-2010, 09:00 PM | #3 |
ok. yeah maybe its something simple like that.
02-03-2010, 09:03 PM | #4 |
Always check the simple things first.....
02-03-2010, 09:05 PM | #5 |
lol. yeah i always head for the most complicated. I will check all my connections when i get to the shop in the morn. thanks glock
02-03-2010, 09:49 PM | #6 |
Robert Olson Transport
9/10 of the time its the wiring at the switch isnt making good contact on GM power windows and locks of this genre
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
02-03-2010, 10:00 PM | #7 |
Location: Where I come from, it's cornbread and chicken...
Mine don't work with either switch lock or unlock...how would I go about troubleshooting it...or should I just replace the relay...how much you think something like that costs...thanks guys...
Chuck. |
02-03-2010, 10:05 PM | #8 |
thanks for all the suggestions. I will check behind the switch first.
02-03-2010, 10:19 PM | #9 |
Chuck - I'm not sure what the relays would cost. Check you r fuse block, not only for the fuse but I believe the main power wire plugs into the fuse block as well. Start were the power starts, then check the relay. It's above the gas pedal, closest to the firewall, and the right side of the bracket.
Also, both of you, sometimes the wires that run between the door and the door jam can break, so that's a possibility too.
02-03-2010, 10:20 PM | #10 |
I think the relay is pretty expensive. I also thought of just replacing it to see if it would fix the problem, but im going inspect all of the connections first like suggested.
02-03-2010, 11:17 PM | #11 |
Hitchmaster,
I've got a relay and switches/wiring if you need them. Tom |
02-03-2010, 11:32 PM | #12 |
awesome!! If I end up needing any parts, i'll for sure be giving you a shout.
02-04-2010, 12:37 AM | #13 |
I have a spare relay out of my dad's truck I'm parting out now that I think of it...can someone post a pic of the fuse box and circle the relay I need to replace...thanks guys
02-04-2010, 10:39 AM | #14 |
Project Optimus Prime
x2 on wut fat hoe said
84 SWB work in progress 89 burb 1500 (parts pig) LOL 08 ford focus (I know, I know) Wifes car "I said it b4 and i'll say it agian wiring is my worst enemy":devil: |
02-04-2010, 11:07 AM | #15 |
huh ???
I'd check the switches first. Mine quit working and all I did was take the switches apart and clean the contacts. They work great now...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
02-04-2010, 11:35 AM | #16 |
I have the opposite problem on my drivers door. I hit the lock button and it will not unlock. The knob tries to move, so it isn't the switch. I couldn't pull the knob up either. I ended up using a "jimmy stick" to unlock it and haven't tried to lock it again.
I can still count my vehicles on two... wait three hands. Last edited by Damien; 02-04-2010 at 11:36 AM. |
02-04-2010, 11:47 AM | #17 |
damien yours sounds like a bad motor or whatever they call the actual thing that pushes up and down the button for the lock
02-05-2010, 02:24 AM | #18 |
here's a pic...so which one is the door lock relay...is it the blue-greenish one in the lower right corner or the silver square box above the blue-greenish one...
thanks guys... Chuck. Last edited by Stitch; 02-05-2010 at 02:25 AM. |
02-05-2010, 04:41 AM | #19 | |
In the Forgotten far North.
That silver rectangular one is the 30amp circuit breaker for your power windows
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
02-05-2010, 04:54 AM | #20 |
I do believe the part you are looking for resembles this guy:
Other pics available if that doesn't do it. Last edited by 83GMCK2500; 02-05-2010 at 04:54 AM. |
02-05-2010, 03:46 AM | #21 |
I went through the whole power door lock issue on my 83 C20 before I realized that it was just rust on the lock rod assembly. Try pulling off the inside door panel and spray some WD40 on the lock rod and hardware, then work the switch back and forth. Might save you actuator and switch costs. The switch harness connectors do work loose, so try wiggling, removing/reinstalling the connections. Good luck.
02-05-2010, 07:50 AM | #22 |
thanks...I have a spare one of those also...gonna try it this weekend and see what I get...thanks guys...
02-05-2010, 10:19 AM | #23 | |
BTW Fat Hoe - The greenish round one on the fuse block is the flasher.
I mentioned this earlier: Quote:
02-05-2010, 08:50 PM | #24 |
I misread...thought you said right side of the fuse block...lol
02-05-2010, 08:58 PM | #25 |
does it also do that if you use the passenger switch? If the pass side works them fine then its gotta be the switch. they're less than ten bucks
