Old 02-04-2010, 11:35 AM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
4/6 drop towing ?
Are any of you guys towing with a 4/6 drop? I am going to install the ECE kit and wanted to know if it might be possible to pull the boat. I will be running 20X10's in the rear with 275/40/20's.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 02-04-2010, 11:38 AM   #2
SCOTI
SCOTI's Avatar
Re: 4/6 drop towing ?
I have more drop than that on my 74 (and my 68 before that). Both towed my 18ft car trailer around w/a vehicle w/o issue.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-04-2010, 02:45 PM   #3
crakarjax
crakarjax's Avatar
the consensus seems to be that you will bottom out, and thus it is preferable to use bags if you want to tow with a drop.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 02-04-2010, 03:32 PM   #4
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I am not gonna bag it but trying to figure out if I could get by with one less truck.
Old 02-04-2010, 03:56 PM   #5
crakarjax
crakarjax's Avatar
Bagging it costs a lot less than an extra truck!
Old 02-04-2010, 04:03 PM   #6
SCOTI
SCOTI's Avatar
Depending on tongue weight, you can tow w/a static drop. I wouldn't do just drop springs in the rear; I'd go w/4" springs & 2" blocks. That being said, it would be a simple swap to rear bags & ensure the ability for towing. 2 bags, required fittings, DOT air line, & 2 schrader valves for filling. Just add air when you hook up the trailer & bleed it out using a tire gauge to verify pressure just like a tire when you're done.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-05-2010, 01:21 PM   #7
Hart_Rod
Hart_Rod's Avatar
What he said, . I think this will be the only safe way to do it....
Hart_Rod is offline   Reply With Quote
Old 02-05-2010, 01:11 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
SCOTI.... did the SWB tow vehicle seem to handle well with the extra weight behind it? I've heard some people feel as though there was a little to much behind weight the tow vehicle.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-05-2010, 03:12 PM   #9
SCOTI
SCOTI's Avatar
Across town... no problem. Over the road? I'd want a larger tow vehicle.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-05-2010, 03:30 PM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That's what I was looking for, thanks SCOTI!
-Nate
