Old 02-04-2010, 05:57 PM   #1
bluex
bluex's Avatar
Hour Meter
Does the hour meter in the cluster only go to 2-3000 hrs before it rolls over back to 0? I hardly ever look at the one in my 07 Classic and flipped past it yesterday after resetting the trip odo and it was on 15.5 hrs. I cant remember if it was close to 2k or 3k hrs before. The digits all work on the odo and trip odo though. I thought it was weird that it would roll over that low with so much space left on the display? I mean if it can show 1000 hrs, then it should be able to show 9999 at least?
Any ideas, the truck has about 54k on it, but they must be mostly highway b/c I bought it with 33k and it showed around 900 hrs when I got it. I think the last time I looked at it, it was over 2k hrs but I never really pay it any attention. Except when I saw it only showed 15 hrs...
bluex is offline   Reply With Quote
Old 02-04-2010, 06:02 PM   #2
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Re: Hour Meter
Has the cluster been replaced? Are you looking at the timer or the actual hour meter? Mine has both in my 03, and I am at right around 4800 hours on the hour meter, but I can reset my other timer any time I want.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 02-04-2010, 06:23 PM   #3
bluex
bluex's Avatar
Re: Hour Meter
The cluster has not been replaced by me or by the dealer according to their records. The truck is a SL, so it only has the odo, 1 trip odo and hr meter. I dont know if it can be reset as I didnt get a owners manual with it either.
Old 02-09-2010, 04:57 PM   #4
bluex
bluex's Avatar
Re: Hour Meter
bump,
No ideas anyone?
Old 02-12-2010, 12:06 AM   #5
463
463's Avatar
Re: Hour Meter
the hour meter i think counts to 9999 hours. seen a lot at the 6000+ mark. ave truck should have 2500 hours for every 60000 miles.
Trueman
463 is offline   Reply With Quote
Old 02-13-2010, 10:28 PM   #6
Truckism
Truckism's Avatar
Re: Hour Meter
My 2003 kept resetting the trip meter and randomly changed language. At first, I thought someone was f'ing with me. The dash was replaced under warranty.
'03 2500HD Crew Duramax Allison
'70 Custom-10 LWB Fleetside
'69 C-10 SWB Fleetside 4X4 4-Speed
'72 VW Drag Car
BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=359544
MY RIDE: http://67-72chevytrucks.com/vboard/s...d.php?t=347614
Truckism is offline   Reply With Quote
Old 02-14-2010, 12:01 AM   #7
JohnC
JohnC's Avatar
Re: Hour Meter
My 03 is in the 4,000 range.
JohnC is offline   Reply With Quote
Old 02-15-2010, 09:34 PM   #8
GCncsuHD
GCncsuHD's Avatar
Re: Hour Meter
Saw this today:
.IPC Engine Hour Meter Resets - keywords cluster DIC display hour meter intermittent start up #PIT4368A - (05/29/2007)[b]2003-2007 Chevrolet Silverado Classic2003-2007 GMC Sierra ClassicSome owners may comment of the ipc engine hour meter resetting. This concern may be very intermittent and normally occurs at key up and/or start up.
GM Engineering is aware of this concern and working on a correction. At this time there has been varying success repairing this concern with the following information:
<LI type=1>Check the battery/s with the Midtronic's battery tester and also perform a load test using a Vat40 or similar load tester to make sure the battery/s are in good condition. We have found in some cases a weak battery could cause this concern, this step is very important on vehicles with the 6.6L Diesel Engine where both batteries are used for cranking the engine. <LI type=1>Check the battery cables and make sure all connections are clean and tight. <LI type=1>Check the IPC powers and grounds (G200, G203, G100, G110 and the braided ground strap between the engine and cowl G104 and G107) connections and make sure they are clean and tight. 1.If the IPC has not been replaced, replace the IPC.
ΜΟΛΩΝ ΛΑΒΕ
Old 02-16-2010, 02:40 AM   #9
Gray Ghost
Gray Ghost's Avatar
Re: Hour Meter
Well that explains mine going from 3045 hours to 3.1 the other day. I did not reset it myself...just happened during a road trip. I better write that number down before I forget it.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 02-16-2010, 05:28 PM   #10
bluex
bluex's Avatar
Re: Hour Meter
Its probably my battery then. I have noticed lately on the cold mornings it is having trouble starting the truck. Thats probably what did it. I'm not too worried about it.
Old 02-16-2010, 09:51 PM   #11
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Hour Meter
My truck has 3,424 hours on it and a little over 122,000 miles, so it's an average of 35.6mph. Neat.
Hopefully it's just your battery.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-16-2010, 11:39 PM   #12
fiddy9apache
fiddy9apache's Avatar
Re: Hour Meter
my work truck has 94500 on it and has 3800ish hours.
fiddy9apache is offline   Reply With Quote
