Old 02-05-2010, 06:42 PM   #1
lonelywanderer
can a 57 hood fit a 58/59
can a 57 hood fit a 58 59 chevy truck? looks similar but wanna double check
lonelywanderer is offline   Reply With Quote
Old 02-05-2010, 06:52 PM   #2
mbgmike
Re: can a 57 hood fit a 58/59
Thats a good question.
mbgmike is offline   Reply With Quote
Old 02-05-2010, 07:02 PM   #3
GRIMSS
GRIMSS's Avatar
I don't think so. The fenders on the 58/59's are wider for the double headlights. So the 57 hood would be too wide for the later.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 02-05-2010, 07:18 PM   #4
lonelywanderer
damn, they looked similar and the hood is a good deal.
Old 02-05-2010, 07:47 PM   #5
1sik52
it will work if you want to swap the entire front cap
1sik52 is offline   Reply With Quote
Old 02-05-2010, 09:32 PM   #6
lonelywanderer
i thought about it but my front end is in really nice condition, just the hood has louvers which i dont like and shipping a hood to hawaii is crazy expensive.
Old 02-05-2010, 09:40 PM   #7
lonelywanderer
can anyone measure across their hood on the 57 in the front for me so i can compare the widths?
Old 02-05-2010, 09:48 PM   #8
addicted2dunes
Insane In The Membrane
addicted2dunes's Avatar
I think they will all interchange between 55-59 the 58-59 fenders are different but I think the hood measurements are the same. I'll have to see if I can get to my hood to pull some measurements.
addicted2dunes is offline   Reply With Quote
Old 02-05-2010, 09:51 PM   #9
addicted2dunes
The front of my 57 hood measures about 41.5"
Old 02-05-2010, 10:20 PM   #10
Kabwe
Certified Car Nut
Kabwe's Avatar
No it will not fit as bolt on but I believe anything can be modified. The whole front clip is different. I went from a 58 to a 55. The Fenders, inner fenders, and even the radiator support is different between 55-57 and 58-59. When I changed my frontend to a 55 I had to do just as 1sik52 said.
Kabwe is offline   Reply With Quote
Old 02-06-2010, 02:30 AM   #11
lonelywanderer
cool, i was hoping someone that did the front conversion could chime in. might just but it and mod it to work.
Old 02-06-2010, 03:49 AM   #12
addicted2dunes
Huh, I know that the core support, fenders, and inner fenders are different. But I thought the hood dimensions were all the same for all years, just different styles. 55-56 smooth, 57 bullets, and 58-59 had the high sides.
I guess they could be different dimensions also, if you have access to that 57 hood why not pull some measurements, the other thing that is probably different is the hood hinge mounting dimensions since 55-57 mount to the firewall and 58-59 mount to the inner fender.
Old 02-06-2010, 11:27 AM   #13
57ExtCab
I'm Not at the shop.But I know they are different. Talked about this once over on the "BOLT" . I have both sitting next to each other and thought the same but after it was discussed, I took a closer look.
I thought it was the length frt to back.
ITS NOT A BOLT ON 4 SURE
Then again the Wife could be RIGHT
"Just cause I Drink alot of Bud that does'nt make me WISER"
57ExtCab is offline   Reply With Quote
Old 02-06-2010, 09:57 PM   #14
JMR5
JMR5's Avatar
As most others have said, it isn't a bolt on affair. There is a guy in Nor Cal who put a 58-59 hood on his 55 chevy, of course with modification. You can see what he did to accomplish it here..... http://www.jalopyjournal.com/forum/s...d.php?t=355930
JMR5 is offline   Reply With Quote
Old 02-06-2010, 11:36 PM   #15
addicted2dunes
Well, while I was at the junkyard today I measured a 58-59 hood and they are different. My 57 measures 41.5" and the 58-59 measured about 38.5"
Old 02-07-2010, 01:29 AM   #16
cajundragger
does anyone know if a '59 frame is longer than a '56 frame from the core support forward?
cajundragger is offline   Reply With Quote
Old 02-07-2010, 02:39 AM   #17
lonelywanderer
thats a cool link. i think it got sold already so i guesss the experiment is on hold. hopefully a 55/56 hood pops up as i like the look of that hood better than the 57 one
Old 02-07-2010, 12:36 PM   #18
Kabwe
Certified Car Nut
Kabwe's Avatar
Yes it is I had to cut about 2 3/4 inches when I changed over to a 55 front end. I'm not sure if that's the exact measure me I cut going by memory, but I do have the ends I cut off if you need them measured. Just let me know.
Old 02-18-2010, 06:48 PM   #19
dwcsr
Hollister Road Co.
dwcsr's Avatar
2.5" all in front of the ibeam so you can trim to use as a 55-7
Old 02-07-2010, 01:30 PM   #20
cajundragger
I can measure them, I just wanted to make sure that I do indeed need to cut them.
thanks
Old 02-18-2010, 03:17 PM   #21
mike16
on the fire wall where the hood hinges bolt up the dimension between the hood hinges on a 55-57 are not the same as the 58-59. the 58-59 are wider across that dimension
mike16 is offline   Reply With Quote
