Old 02-06-2010, 11:54 PM   #1
corvette6698512
Broke the rearend.
Hey guys, Im new to the forums. My name is Chris. I have a '68 pickup that has been a good truck sofar. I decided to mess around with it a little bit to see if it would do a burnout. Put it in 1st(its a 3 speed with 292) and dumped the clutch(not really sidestep, just released it quickly) First time was awesome. Didnt break a sweat, but the second time made some bad noises. The driveline was dragging, and the diff on the 12 bolt was turned up way further then it should be. It broke the welds that keep the diff from twisting. Iv never seen this or heard of it. I don't think it will be too hard to fix, but I thought id share my little mishap. I think I can turn it back down and weld it back together. If not, i'll look for another 12bolt. No more beatings for this old pickup, I like it too much to keep breaking it. Pics:
corvette6698512 is offline   Reply With Quote
Old 02-07-2010, 12:55 AM   #2
shaneo2112RUSH
Junior Member
shaneo2112RUSH's Avatar
Re: Broke the rearend.
Wow!! alot of tourqe or just old age!!
I,m not suprised the axle welds sheered off!! that was a weekness in the GM axles!!
I would take it to a drive line shop to make shure the axles strait across!
Love the One Tire Fire Mark!!
1968 LWB C10 "Project LADY EYE SORE" (She is my baby and sent me to the hospital 3 times for eye injuries lol) who said love hurts??
shaneo2112RUSH is offline   Reply With Quote
Old 02-07-2010, 01:02 AM   #3
gonzo6869
Cops, ha, catch me if you can!
gonzo6869's Avatar
NICE! It showed you it has no prob laying down rubber. On the other hand it showed you it has no prob hooking up either
Hope its an easy fix, keep us updated.
72 C-10 Stepper
350/TH350
3.73 in the back
Edelbrock intake and Carb
Hooker Comp Headers
275/60R15 on Rallies
gonzo6869 is offline   Reply With Quote
Old 02-07-2010, 12:59 AM   #4
corvette6698512
I suppose I beat on it a little harder then I should have. This old 292 sure runs strong. anyways, A driveline shop huh? I was hoping I wouldn't have to pull it lol.
Old 02-07-2010, 01:06 AM   #5
americanmusc1e
americanmusc1e's Avatar
WOW, I broke the spider gears in mine because I did two many a one-wheeled burnouts with my 383, but I never suspected that you could break those welds without breaking an axle or the diff carrier.
this is what I did
BTW, welcome and congrats on a fine looking truck
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 02-07-2010, 01:09 AM   #6
corvette6698512
Thanks for the great replys. I really do like this truck. I sold my subaru to get it, and I don't regret it at all. I know i didn't break the diff or the trans. I think I got lucky on this one. I have heard the 3 speed column shift transmissions don't take too much abuse. Im hoping to have it fixed in the next few days. Thanks again.
Chris
Old 02-07-2010, 01:13 AM   #7
70cst
70cst's Avatar
Best of luck...Sorry to hear of your mishap.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 02-07-2010, 01:53 AM   #8
capev86
maybe swap axles with a good 10 bolt (trailing arm perches needed and shock mounts moved). i hear the 12 bolt is not as rugged as the 10 bolt. also remember nothing lasts long when you beat on it. make sure everything is in tip top shape and also maybe use synthetic fluid (diffs get hot). supertech, mobil 1 and several other brands make it. i put royal purple in my the 3onthetree in my 72 burb 3/4 ton and plan to change out the rear diff fluid in the HO52 when i swap in my 4.10 third memeber. i will be towing with my truck and the drivetrain only has 74,000 gentle miles and i plan to keep it in that condition.
capev86 is offline   Reply With Quote
Old 02-07-2010, 03:20 AM   #9
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Impressive! I've taken out some rearends but never done that....yet. I'd find another 12 bolt in a junk yard and swap it in, no fab required. Unless you like to modify then I'd skip the 10 bolt and go for a 9"
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-07-2010, 02:02 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Don't know where you heard that... the 12 bolt truck rear end is a good rear end with a larger ring gear than a 10 bolt. The axles are bigger too...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 02-07-2010, 03:47 PM   #11
usmcchevy
usmcchevy's Avatar
Gary
It has something to do with the 10 bolt having a larger pinion shaft.
Build thread
LSx Swap FAQ index
Old 02-07-2010, 05:30 PM   #12
GASoline71
GASoline71's Avatar
It might have a larger pinion shaft but is a weaker unit all together. If they were that solid of a rear end, there would be more people swappin' out 12 bolts for 10 bolts...
Gary
Old 02-07-2010, 03:22 AM   #13
corvette6698512
I dont plan on doing anything like that again. It was my stupidity, and I knew it might break. I'll look around for another 12bolt and be nice to it.
Old 02-07-2010, 04:11 AM   #14
highperf4x4
Welcome to the forum.
I pulled a similar stunt but I broke the front yoke off the driveshaft in my 4x4.
highperf4x4 is offline   Reply With Quote
Old 02-07-2010, 06:21 AM   #15
Shaky
Six in a row makes it go...
Shaky's Avatar
There's just a puddle weld that holds the tube into the main housing. That's why the differential shops do a 360 degree weld on the tubes when building up a performance rear.
Never underestimate the ability of a 292 to make gobs of low-end torque.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 02-07-2010, 06:50 AM   #16
Sublvr72
Sublvr72's Avatar
kids....
lol
if there's no damage to the axle other than the mounts, just weld it back down after you set it. I'm guessing you broke more than that though...
Sublvr72 is offline   Reply With Quote
Old 02-07-2010, 08:39 AM   #17
bigsnookmaster
bigsnookmaster's Avatar
Originally Posted by Sublvr72 View Post
kids....
lol
I agree, if it isn't leaking, weld it. I would tack it in, spin the yolk and see if the rear is making any noise. If all else fails, replace it. But it would suck if you replace it and all it needed was to be re-welded
bigsnookmaster is offline   Reply With Quote
Old 02-07-2010, 10:20 AM   #18
junkyardjohn
junkyardjohn's Avatar
[QUOTE=bigsnookmaster;3785577]I agree, if it isn't leaking, weld it. I would tack it in, spin the yolk and see if the rear is making any noise. If all else fails, replace it. But it would suck if you replace it and all it needed was to be re-welded[/QUOTE YOU BET.. I'D LOOSEN THE U-BOLTS , TURN IT BACK WHERE THE OLD WELD MARKS LINE UP & WELD IT. HECK YOU ONLY GAMBLE 15 MINUTES. YOU JUST MIGHT GET LUCKY. IT'S SURE WORTH A TRY. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 02-07-2010, 07:16 AM   #19
eagleuh1
eagleuh1's Avatar
Did it brake the u-joints or yoke at the rear-end, thats a lot of angle for a spinning mass. Also the first time for seeing this happen. Awsome burnout man!!! Fix what you got, as long as the tubes didn't bend or crush/twist up where they go into the diff. housing or at the perches. Good luck.
eagleuh1 is offline   Reply With Quote
Old 02-07-2010, 07:49 AM   #20
big_al_71
big_al_71's Avatar
nice peg leg burn out
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 02-07-2010, 01:23 PM   #21
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Power of the six popper....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 02-07-2010, 01:55 PM   #22
chas350
Hey nice job! lol
I broke the spring perch's off my axel on the 70 camaro I had years ago. Thats what happens when you put slicks on it at the drag track and it really hooks up after a burnout lol. The diff twisted up so hard,the u joint broke and the yoke punched a hole through the floor. HAHA that was the last time I took it to the track!
Another time I blew the rear up and broke the c clips, both axels slid out and set the diff almost on the road, what a sight that was through the side mirrors with the wheels/tires running about 2' outside the fenders! That was funny, my friends never let me forget that one.
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 02-07-2010, 02:50 PM   #23
brad_man_72
the boat guy
brad_man_72's Avatar
definatly want to make sure the driveshaft is still relativley straight, make sure the pinion and pinion yoke arrent damaged.
hell id bolt the rear end down and take a gentle ride around the block before i even bothered welding it.
who says a I6 couldnt do a burnout, heres a memeber winning the 09 midwest all truck nationals burnout contest with his 250 w a 3 speed.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-07-2010, 02:03 PM   #24
capev86
yeah.....straight 6's are very efficient and make great low end torque, especially the big boy 292. that's why they put an I6 in the trailblazer instead of sticking with a v6 like in the old s10's. with or without work, they make great towing engines due to their low rpm performance characteristics compared to V engines. the 292 also has a 4-1/8 inch stroke which is pretty much unmatched even by modern stroker engines.
you can hot rod up the 292 with a 4 barrel intake, split exhaust manifold to go dual exhaust. that magnaflow x-pipe ss exhaust for the 67-72 would probably work great with a little tweaking to match up. there are also roller valvetrains and you can put a petronix kit in the factory distributor for electronic ignition. they even have a TBI system for the 292 i hear.
i'd love to put a modernized 292 in an early 50's burb or panel truck (i like the 1 ton extended wheelbase). but i have my 72 burb and many other projects needing my time and money.
Old 02-07-2010, 08:54 PM   #25
corvette6698512
So I found out its a lot harder to twist that back to the stock location then just "twist it back". I think I will have to put a chain around the yoke and under the diff and see if I can pull that back and twist it down.
