Old 02-08-2010, 04:39 PM   #1
Roscoep
Roscoep's Avatar
Has this ever happened to you?
This is what happens when you park one in a wooded area in the fall and through the winter. I'm sure it's a squirrel nest, but might be another kind of rodent. I haven’t removed it yet, can't wait to see the wiring.
Robert
71 Chevy SWB
Roscoep is offline   Reply With Quote
Old 02-08-2010, 04:48 PM   #2
culp7
HickTown
culp7's Avatar
Re: Has this ever happened to you?
haha that happened to me on my 76 dodge.
its a B%$#& to clean up
by the way nice to see someone from jackson... (I was born there!!)
1993 Ford Mustang Vert w/ 2.3
1969 Chevy C/10 w/350
1968 Chevy C-20 w/250
1976 Dodge Aspen W/ 225
2000 Toyota Tundra w/4.7
1987 Dodge Ram D-100 w/360
255/70-15
___________
(oo)══╬══(oo)
culp7 is offline   Reply With Quote
Old 02-08-2010, 04:59 PM   #3
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Damn rodents, that's why i kill every squirrel i see. I know Ive shot close to 200 of them since Ive lived here in the past 10 years. Never seen a squirrels nest in a truck I see them up in the trees all the time, its probbly a packrat.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 02-08-2010, 04:52 PM   #4
Fitz
Try parking one in Arizona...they don't build nests; they eat all of the wiring. Insulation is like Filet Mignon to a packrat.
Fitz is offline   Reply With Quote
Old 02-08-2010, 05:05 PM   #5
lovnthe70
lovnthe70's Avatar
oh man!! mine was parked here in arizona for about 8 years and luckly the only thing i found was a black widow!
1970 GMC- 454
DONT GIVE ME NO JIBBA JABBA!!!
lovnthe70 is offline   Reply With Quote
Old 02-08-2010, 05:11 PM   #6
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
That could have been worse!
Tony
Old 02-08-2010, 05:31 PM   #7
292farmer
292farmer's Avatar
i've had that happen i jacked it up then used a leaf blower and blew them out from below to start, then did remainder fromtop, keep aircleaner on when doing this.. also pull the carb off and check intake manifold somehow a mouse got past the carbs butterflys in my 86 and was rotting in the intake made a mess of the motor ran crappy and plugged up my spark plugs with gunk took me a month before i figured it might be the carb so i took carb off and saw a decomposed mouse or what was left to him melted into the bottom of the manifold. yuck
292farmer is offline   Reply With Quote
Old 02-08-2010, 06:49 PM   #8
dfwright
dfwright's Avatar
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 02-08-2010, 05:09 PM   #9
John Fabris
TOTY 2006
John Fabris's Avatar
I think that is funnier then heck. Fits right in with the picture of the heater ducting packed full of peanuts!!!
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 02-08-2010, 05:51 PM   #10
michael bustamante
michael bustamante's Avatar
When I worked at toyota, we would get cars in from people that lived in the sandias (mountains) and we`d open the hood and find mice in squirrel cages, nests like that, half eaten cactus, hood insulation eaten up, wires arcing from teeth marks, you name it!!! and of course black widows, (gotta watch out for those ladies)
1967custom
michael bustamante is offline   Reply With Quote
Old 02-08-2010, 07:19 PM   #11
Shyguy
Junior Member
Shyguy's Avatar
One time I went up to my brother's hill farm driving my truck and replaced the damaged trailer connector on his travel trailer.
When I got home out here in the flatland I raised the hood on my truck to check the oil and was greated by the biggest brown snake I have ever seen, lol.
I could tell by the very pointed tail it was not a bothersome snake.
It had to be at least 4 ft long and crawled off the engine down onto the ground. Of course I gave it plenty of room as it crawled into the corn field.
Finding snakes out here in the county is not usual, but if you find one when you don't expect it can give you a start.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 02-08-2010, 09:17 PM   #12
glider_6969
I recommend you also take the heater box apart, When I got my first truck and got the heater running and warm...........boy did it stink,,, I found that some mice decided to move in.
glider_6969 is offline   Reply With Quote
Old 02-08-2010, 10:11 PM   #13
Hubscrub
Cruzin
Hubscrub's Avatar
the new "nature series" engine cover you might want to take the cowl off and clean out the vents i took a piece of heater hose and taped it to my vacuum and stuck in down it the holes in the cab and in the hole in the inside of the cab and got all kinds of (nature stuff) out
Hubscrub is offline   Reply With Quote
Old 02-08-2010, 10:20 PM   #14
Ole Blue 71
Ole Blue 71's Avatar
They haven't gotten into my truck but, the neighborhood squirrels were storing nuts in my neighbor’s Arctic Cat. He was riding and the throttle jammed WOT! Very luckily, the nuts blocked enough airflow that it killed the engine instead of it taking off across the field on him. We pulled it home and I pulled a couple nuts out of the throttle body and at least 2 dozen nuts out of the airbox.
He was very lucky that day!
71 C-10 "Ole Blue"
72 C-15 - Current Project
72 K-10 - In Pieces (Sold)
70 C-10 - "Goldie" (Sold)
66 Impala Convertible
20 FLTRXS
Ole Blue 71 is offline   Reply With Quote
Old 02-08-2010, 10:22 PM   #15
Number98
Prestige Worldwide
Number98's Avatar
Number98 is offline   Reply With Quote
Old 02-10-2010, 09:25 PM   #16
70Custom10Nut
70Custom10Nut's Avatar
Would that be the "Real Tree" engine dress up accessory kit?
70Custom10Nut is offline   Reply With Quote
Old 02-10-2010, 09:41 PM   #17
mbgmike
That is funny. Nope never happened when I lived in trees
must have been him
mbgmike is offline   Reply With Quote
Old 02-10-2010, 11:03 PM   #18
toms68cst
toms68cst's Avatar
I went to start our 94 Olds 88 that's sat in the snow for about a month just last weekend. I opened up the hood to get ready to jump start it and noticed that my spark plug wires were totally GONE! Upon further inspection, it seems that one of our local squirrels had aquired a taste for spark plug wires. I don't see any other damage (I hope)
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
