02-08-2010, 11:05 PM | #1 |
Sanderson Headers
Any one running any of these headers?
http://www.sandersonheaders.com/inde...cPath=21_23_35 Just looking for some feedback on them...... Thanks
1972 Chevy C10 SWB 1999 GMC Sonoma Mini 2008 Yamaha R1 2007 Harley Nightster |
02-08-2010, 11:12 PM | #2 |
Re: Sanderson Headers
I believe that is the popular header most everyone runs on here.
02-09-2010, 08:20 AM | #3 |
Which set is most popular... Any Pictures?
02-09-2010, 09:08 AM | #4 |
Redefining LowBudget
keep in mind how low you are full length heads wear funny if your to low..I have a post about the 88 to 95 3/4 header to keep it above the frame rail..so far no feed back??
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
02-09-2010, 11:23 AM | #5 |
I've got Sandersons on my '70, and I really like them. The head flange is very thick, (3/8") so there is no need for a gasket at the head, (high heat silicone only)and the collector is 2.5", so I just welded the exhaust pipe directly to a bolt on collector flange, eliminating the need for a reducer/collector. I also like the fact that they don't hang down below the frame, but they do hug the trans pretty tight, and I don't think that I could remove the trans without removing the headers first. I'm not sure what the part number is, but I think mine were made for early 90's chevy trucks.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
02-09-2010, 11:00 AM | #6 |
It might just be me but most of them look like they aren't tuned. Is this something that should be considered? I'm thinking about putting a set on my 350. I've never had headers on any vehicle because I prefer stock but I think, in this case, I'm going to trim my engine up for just a bit more performance.
02-09-2010, 11:13 AM | #7 |
These are Sanderson BB-4 blockhuggers. On my 67 Stepside they tuck up between the frame rails so nothing is hanging down and they did not require much in terms of cutting to fit. On the passenger side I needed to put a small oval notch in the upper part of the frame rail but it was only 3/8 inches deep and 2 inches long. If this motor was anything other than a 572 that would not have been required but the heads are very far apart on this tall deck block. They also required relocating the oil filter which I did.
02-09-2010, 11:21 AM | #8 |
I'm running em on a zz4 (block huggers) and they work great. thick flanges. I run copper gaskets& no problems. Pat
02-09-2010, 01:19 PM | #9 | |
How is it gettin the oil filter off? It looks a little tight
02-09-2010, 02:16 PM | #10 |
I did say it was relocated.
02-09-2010, 09:01 PM | #11 |
Mr. Fitz, Professor Spoof must point out that the tag line about "intra-personal" problems and explosives suggests that one is intending to blow ones self up. To blow up other individuals, the usual source of one's misanthropy would be the result of "inter-personal" problems. Class dismissed.
Oh yeah, I have the block huggers. There collecting nothing but dust right now in the basement. The Zoomies are cool!
71 GMC 1500 LWB |
02-09-2010, 11:04 AM | #12 |
I have a pair they work very well.
02-09-2010, 09:24 PM | #13 |
Check out my build thread. I have a set of the mid lengths on mine, and they fit and look (ceramic coated) way better that the long tube headmans I had.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
02-09-2010, 09:50 PM | #14 | |||
Union Electrician
I have these and yet to be installed, they look to fit almost like the ramshorns
http://www.sandersonheaders.com/prod...products_id=62
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
02-16-2010, 11:28 PM | #15 |
i have a set, cc10 is the part # i believe. best headers i have ever had....
02-17-2010, 03:06 AM | #16 |
Addicted user
I just got a set of CC 10 headers for my 71 2wd blazer from ECE and they don't with fit my 4 speed manual trans linkage Z bar. I have to do some mods to where the Z bar is pivoted from. Anyone else have this problem?
heres what they look like on the passenger side so far.. |
08-02-2014, 05:25 AM | #17 |
Dang those look nice!
