Old 02-09-2010, 02:54 PM   #1
BGRAFX
water pump
I found a cheap suburban that the previous says needs a new water pump, or maybe a radiator or maybe a thermostat.....He really has no clue what's wrong with it other then "it leaks from the area behind/below the fan.
My question is what needs to be done in order to drive the beast home? can i fill it up with antifreeze and hope it makes it the 45mile drive home?
Thanks in advance for your help.
BGRAFX is offline   Reply With Quote
Old 02-09-2010, 07:11 PM   #2
Daggar
Daggar's Avatar
Re: water pump
It sounds like a water pump issue from the description. If it's just a little leak then it is probably antifreeze comming out of the weap hole on the pump. That indicates the seals on the pump are wearing out. So if it's that small of a leak I would say 45 mi is not out of the question. if it's more then that then maybe your pushing it.
1999 Chevrolet Suburban 2500 4x4 - 454, 4L80E and lots of other fun options
1967 Chevrolet C10 Longbox Stepside - Restored
1991 Chevrolet Suburban 2500 4x4 - 350, 4L80E - Not dead but severly crippled
1987 GMC Suburban 1500 - Now some retired guy's trailer hauler
1992 Lumina Z34 - I'll miss that PITA
Daggar is offline   Reply With Quote
Old 02-10-2010, 02:47 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
Re: water pump
make sure no cracked block crawl under and look for cracks around mounts,or fill and run while looking,water would be fine if not to cold
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 02-10-2010, 03:02 PM   #4
BGRAFX
Re: water pump
It's 20degrees here today. I think i'm going to pass on the suburban I really want a crewcab short bed.
