Old 02-11-2010, 09:35 AM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Clunk when I turn?
My dad has a 83 K1500 Suburban, 10b/10b. When you turn fast whether driving or sitting it makes a soft clunk. Like when you are in 4wd and turn all the way the axles "pop". But its in 2wd and just being turned fast. Its stock suspension/steering and 31x10.5/R15 BFG A/T's. What do you guys think it is?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 02-12-2010, 12:13 AM   #2
Big-Blue
Big-Blue's Avatar
Re: Clunk when I turn?
Could be a locker and if so, probably not a big deal. Is it something new?
Big-Blue is offline   Reply With Quote
Old 02-12-2010, 07:04 AM   #3
LONGHAIR
The most likely cause is the axle joints in the front end. The get rusty and stiff. Even though the truck is in 2 wheel drive and the front axles are not turning, they still have to "bend" when you turn.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-12-2010, 08:13 AM   #4
thirdstreettito
Resident of Here
Lol no. I could never get dad to buy a locker. Thanks though.
How do I fix it? New axle u-joints? WD/40? Are those u-joints greasable?
~Bradley~
Miss having a truck
Old 02-12-2010, 11:36 AM   #5
LONGHAIR
Replacement is the only fix. The factory originals are not greaseable, but you can buy a version that is. <Spicer>
It is a fairly involved process. The entire knuckle needs to be stripped and getting the spindle off can be a challenge. After that changing the joint itself is not that much different than in a driveshaft. The main thing is that it has to be pressed out/in on both halves.
Old 02-12-2010, 07:26 PM   #6
I`d say f it`s in 2wd it would be in the steering.Prolly the draglink,pitman arrn @ sector shaft,or tie rod ends.Check for slop.
Old 02-17-2010, 02:15 PM   #7
gcsupraman
gcsupraman's Avatar
Agreed!
I was chasing down a popping noise myself when turning. I was able to replicate the noise while stopped so I grabbed a friend to watch and determined the steering box became loose from the frame. Is your noise easily replicated so you can do the same?
If not, start by jacking up one front wheel off the ground and pushing/pulling at 12o'clock/6 o'clock and then again at 9oclock/3 o'clock.
Let us know what you find.
-Greg
gcsupraman is offline   Reply With Quote
Old 02-13-2010, 12:38 PM   #8
msgross
msgross's Avatar
would ball joints cause an issue?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-17-2010, 12:54 AM   #9
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yea that's what I was thinking as well. Or something else in the steering!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 02-17-2010, 02:22 PM   #10
thirdstreettito
Resident of Here
I dont know if it can be replicated. It is happening less now. It started last week while backing up a tiny trailer into a tiny spot, as some of you know, 8' trailers are hard to backup. Even the slightest steering change effects the direction of the trailer. I will try to replicate it. Thanks a bunch guys.
~Bradley~
Miss having a truck
Old 02-18-2010, 03:08 PM   #11
wildwilly4x4
Very possible that you could have broken the locating bolt in the driver leaf spring. I have done this before and the U-bolt plate would move a little bit until it bound up on the broken bolt. It sorta made a clunk sound until I found it. Otherwise is prolly a balljoint or your shimmy shock.
wildwilly4x4 is offline   Reply With Quote
