![]() Join Date: Nov 2009
Need a shortcut!!
I just got new "K/5 Blazer" emblems
![]() Is there an easy way to get at the inside of the fender to install the nuts? Do I have to remove the fender completely? Any suggestions? Thanks!
Dustin '97 Dodge Ram (daily driver) '71 Blazer (supposed to be a toy... insists on being a project) '85 Monte Carlo SS (project) |
Re: Need a shortcut!!
You might try taking the inner fender loose and drop it down enough to get your hand up in there.
#3 | |
Most parts stores carry something that I believe is called a speed nut ( not certain on the name) it just inserts into the hole and then you push the emblem prong into it. This is how I did mine. Im not certain how you remove them since I havent had a need to.
Is it a barrel clip? They make some round clips that go inside the drilled holes and stay in place and accept the emblem studs.
Jeremy (NUBOMB) 72K5 CST 350/350/205 1951 Chevy 1/2 ton North Georgia Group "... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman. |
#6 | |
Do the holes need to be drilled out to use these? I'll check with the parts stores as soon as I can..
Possibly it has been so long since I have used them I have no idea what they are called.
SKINNY TIRES RULE!
You need extremely skinny arms & remove the inner fenders. The drivers side is easier than the passenger side.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
no they were a perfect fit in the original holes. I can get the name off of the pack tomorrow if you need it.
![]() Join Date: Feb 2000
I'd be interested in the name off the pack - I tried to use some a while back but they didn't grip the emblem studs very well.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
![]() Join Date: Apr 2000
got mine at napa, used them just this fall,work great!! i believe there 3/16 and they also work for holding the rods in your tailgate handle....
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
Picked some up today & got my emblems installed in just a few minutes!
They worked great! Thank you for the help!!
#13 | |
Its lookin' like a Blazer!
Thats awesome, post some pics of them installed along with the parts and a part number. It could help someone in the future. When ya get a chance of course. ![]() |
I tried to get a picture but I have too much crap in the garage, hard to get a nice picture.. maybe I'll be able to get it out of the garage this weekend.
#15 |
Got a part number of the ones you used Dustin?
#16 |
![]() Join Date: Jan 2007
Are they rivnuts?
#17 |
The bag just says for 3/16" stud
The parts counter guy called them insert nuts, he knew what I was looking for right away so I assume they are reasonably common. I got them at Arnold Motor Supply, they are an Auto Value franchise- $5 for 10 of them, I went there since they have alot of auto body supply stuff. Here's a pic.. Hope this helps!
#18 |
Most people call them barrel nuts.
