Badass
wierd brake problem
ok i should know what the problem is but i cant get this one?
ok just replaced the lower balljoints and now it wonders a little to the right nothin big.but when i hit the brakes it pulls left?
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: werid brake problem
if it pulls left im guessing the right side may be frozen or partially blocked. you can jack it up and see if you can have someone hold the brake and see if the right side wheel turns or you can first try bleeding the right side . If that doesnt help then the rubber line and or caliper. I would also try to flush as much of the old brake fluid as i could at that point..
On edit yeah i shoulda said allignment first unless this is a real hard pull then you can bet its in the brakes
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! Last edited by old Rusty C10; 02-14-2010 at 03:00 PM. |
+ an alignment
Addicted to Rust
![]() Join Date: Dec 2009
Re: wierd brake problem
My guess is the camber changed with the new ball joints. Do an alignment before you do the brake work unless the pull was present before the chassis work. jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
Kid's Mechanic
Did you Take the calipers off? did the brake hose wind up with a twist in it?
STILL PLAYS WITH TRUX
Thats exactly what i was thinkin too
Badass
yes we are going to do alignment at school thursday.but it never had this problem befor i did the ball joints,we did have the calipers off when i had it all apart,ill go look if i twisted a line or somthing.
the funny thing is,i took my ASE test on brakes and was 1qestion away on passing it,so i should know this lol
Crew Cut
i'm thinking bad rubber brake line.
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN ![]() |
