spare tire
The trouble with having a low rider truck is that the spare doesn't fit under the bed, therefore I've been running around without one. Well, no more. I found a smoothie wheel that needed some cleaning up on craigslist for $30, and a pair of low mile BFG Radials haggled down to $50 (so I still have an extra). Add: Misc hardware, chain, lock, and paint from home Depot: $40
Trailer fender from Spectrac: $20. I'm still $50 ahead of what Summit wanted for a new matching wheel/tire, and I gave it a little bit of UV protection in the bed. The tire needed some cleaning up... Mounted up...yes, the center area is painted as a means to treat the surface rust. I also scrubbed down and hit the backside of the wheel with the same gray paint. I'm pretty happy with the rattle can color match to the roof. Locked in place All done. |
its all about the +6 inches
Re: spare tire
looks great.
Only issue I see, is it creates a blind spot. I placed one on the passenger side once and it took me less than a day to move it to the drivers side. |
![]() Join Date: Feb 2001
Re: spare tire
Great creativity...I found out that w/o a spare tire You dream flat tires... and With a jack and a spare you're there on the side of the road fixing a flat. I guess I worry to much about fxing a flat on the side of the road. But with your spare that issues is solved .
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Re: spare tire
Good point...I would not have never thought of that.
Cruzin
Re: spare tire
#6 | |
Re: spare tire
![]() I put it on the passenger side because it's right behind the driver door where I naturally go to put stuff like groceries and crap, and the tire would be in the way. |
Out of the carpool lane.
Re: spare tire
For my lowered truck I use a donut spare from an Astro van along with a vinyl cover I found in the jy.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
Shake and Bake!
![]() Join Date: Feb 2010
Re: spare tire
Nice work, I like the look. Did you make the mount/cover?
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
Re: spare tire
Nice job. Looks great and was a great idea.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Re: spare tire
I made everything but the cover itself. That's a trailer fender I found at a hitch/spring shop.
Active Member
![]() Join Date: Jul 2007
Re: spare tire
Good work D-Rat. The thing I like about is that it didn't require you to weld and can be removed if you wanted to. Also, can be used on either side.
Re: spare tire
thats pretty cool, i like it
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Re: spare tire
terrific idea!!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Re: spare tire
Nice fabricating D-rat. It fits the truck well.
