Old 02-14-2010, 11:33 PM   #1
RED67
Forever Grateful
RED67's Avatar
4 wheel disk brake line setup
is the 4 wheel disc brake lines diffrent than the brake line setup from LMC or other vendors since they didn't have 4 wheel disc back then?? I'm looking to purchase..Thx Ronnie
R.I.P Dad 04-07-42 - 05-27-09
RED67 is offline   Reply With Quote
Old 02-15-2010, 11:26 AM   #2
OhOneWS6
OhOneWS6's Avatar
Re: 4 wheel disk brake line setup
Hey Ronnie,
I am doing a 4 wheel disc conversion as well. What rear calipers are you going to use? I am using the LT-1 F-Body calipers for mine.
From what I can tell with this swap, you will need a fitting to convert the std thread brake line on the truck to the metric thread for the new flex lines to the calipers. Some guys are just bending the end of the metal line a little to make it work others are making new lines. Good luck with your conversion.
OhOneWS6 is offline   Reply With Quote
