1972 K20
![]() Join Date: Apr 2008
Help,
I'm getting ready to re-assemble my truck and I noticed that my tilt steering column has a worn out shift pin hole for the shift lever. What are my options? Does someone make a new collar? I have thought of using adhesive or drilling larger and bushing it. I'm guessing this is a common wear item. What have others done? Anyone else fix this problem with success? |
Re: Tilt steering rebuild available parts
It is a common problem and the part is not reproduced. I had some oversize pins made which worked for a small amount of wear. Bushings are always an option. The other thing you might try is to find someone that is modifying a tilt for a floor shift. You might be able to work out some kind of trade since the shift boss is removed when modifying a column to use it as a floor shift tilt.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
#3 | |
![]() Join Date: May 2006
1972 K20
That would be awesome! The one I have is fine other than the pin hole being oversize. Let me know how you want to do the swap and I will make it happen.
#5 | |
If it is not apart, you will have to totally disassemble, as the bowl is the first part to get reassembled It's the one on the right ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-17-2010 at 02:29 AM. |
Depending on how big the hole is, you could close it up by dimpling it with a center punch all the way around the holes, and then some sort of adhesive to help keep it in place... lab metal is pretty neat stuff
1972 K20
I was thinking I could use liquid metal or something like that to fill the gap. I was hoping someone had already figured out the best way to fix it. Trading parts may be more of a hassle than its worth for both of us! But thanks for the offer.
Bud |
CPP has a whole rebuilt column for sale. I would call them and see if they do sell just the bowl.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Already smoothed mine off or i'd trade ya...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Moderator
![]() Join Date: Jun 2008
I saw this industrial strength soder type material at the local swapmeet a year or two ago. It was VERY strong and easy to apply (welding ligther). Does anyone know what that product might be called? I guarantee it's stronger than JB Weld.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
