Door inner panel replacement
I have inner panel and need to install it on passenger side door. Should I cut the door so that the inner panel slides up under some existing sheetmetal and weld as overlap? There is a lip on the replacement panel.
Thanks as always!
69 C10 lwb, 400 sb, Turbo 400, |
I would weld it as you describe. You will want to seal the inner seam. I would be concerned that cutting the flange off to do a butt weld, could lead to warping.
Jim |
