02-17-2010, 02:00 PM | #1 |
1972 K20
How to replace frame crossmember?
Hi,
I purchase a 73 front cross member for the sway bar mounts from a board member to put on my 72 K20 ... now I want to install it! What does everyone do? Bolt it in ...or does it need to be riveted? Seems like bolts would work loose over time, but riveting seems like a lot of work! Anyone done this before and if so how did you do it? |
02-17-2010, 02:46 PM | #2 |
Re: How to replace frame crossmember?
The sway bar brackets were originally riveted to the frame horns, but you can bolt them on. I use grade 8 bolts, with pinch lock nuts(they dont work loose). On the lower arms, the "C" brackets that hold the bushings for the sway bar, were bolted from the factory. crazyAL
http://community.webshots.com/user/hotrodhorn |
02-17-2010, 04:55 PM | #3 |
1972 K20
Hi Al,
Your suggestion sounds correct for a 2 wheel drive but I have a 72 K20 and I am using a 4x4 cross member from a 73 K20 that has the brackets as part of the crossmember so I have to replace the entire front cross member. That is why I questioned using bolts. |
02-17-2010, 05:37 PM | #4 | |
02-17-2010, 06:46 PM | #5 |
The Older Generation
I have done three complete crossmember transplants, used grade 8 bolts with no problems. Mine have been 2wd but it shouldn't make any difference.... LockDoc
02-17-2010, 08:23 PM | #6 |
The 73 crossmember is not a bolt in replacement, so you will need to modify the way it is mounted. If you look at it you will notice that it mounts at a different angle from the 72 K-10.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
