1948 Chevy Project
some of you may remember my build of a 1950 GMC:
http://67-72chevytrucks.com/vboard/s...d.php?t=289540 currently a new client dropped off his 48 project truck in hopes to pick it up as a driver. unfortunately some of the work has already been done and will need revisiting, however it is in my eyes a good start. the old cab and sheetmetal will sit atop a S-10/Blazer frame. plans are to mimic the same "look" as the 50 GMC, full air-ride suspension, 350 motor, auto trans, power disc brakes, power steering all the modern goodies, however retaining the look and feel of the old truck. follow along if you like for i will update as this project moves forward step by step. as arrived: ![]() new parts: ![]() 195/75-15 on 15x6.5 smoothies: ![]() stock s-10: ![]() dropped spindles, no springs (future airbags) still need to trim spring cup to drop 1 more inch: ![]() looking better: ![]() thanks, Yaril |
and a few others
Re: 1948 Chevy Project
If this turns out like any of your other builds, this is gonna be awesome.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
well the 4-link pan-hard bar and rear bag brackets had arrived (thanks DW welderseries.com) and they look great as always! so im also building another S-10 frame for another AD truck build, but thats just the frame by itself, so i get to do this job twice!
![]() ![]() ![]() think im not going to make this one lay running boards. im about 1-1/2" off the ground and content, even though i got some motivation in the background... ![]() till next time. |
Nice ....... I'm in.
Ratty 46 |
![]() Join Date: Jul 2006
Nice, I like that 4-link is it S-10 specific or their universal one? I talked with DW the other day, super nice fellow. I'm gonna use some of their stuff. Wish I still lived in Miami so I could stop by and see this in person.
Leevon
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
I love the style of trucks you built. I had sent an email question on your site, but I will just ask it here.
On Ozzy's GMC what cross member, and what rims did y'all use? Thanks in advance.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
#7 | |
Ozzys mII is from e-bay. customer purchased so i got no info on it other than the busings it brought for the a-arms are garbage. they already blew out with mearly 2K miles. rims are 14s, main thing if laying out is the goal, is to run 26.5" tall tires, im sure you can research but of my head thats the biggest that will fit in the fender and layout. granted i didnt trim the rear inner fender support. good luck! |
No problem, thanks for the info.
update!!!
set the panhard bar at ride hight 0 degrees: ![]() metal to box frame for frame bag bracket and strength: ![]() looking good, only frame shock brackets left to fab: ![]() ![]() ![]() ![]() close up: ![]() sitting pretty: ![]() more to come... |
![]() Join Date: Jun 2002
looking good, love the wide whites & chrome on these old trucks! By the way, nice welds too
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
thanks i try. always love your truck too man!
bit more progress for today... shock tabs finished ![]() air tank mounted ![]() even got my SBC 283 with 350 trans in the truck for mock up purposes ![]() ![]() steering column will be next. |
Nice progress!!
Ratty 46 |
nice ride, keep up the progress!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
steering looks simple enough, going to order the 3/4 double D joint before i trim the column any more.
#15 |
It looks pretty close but I would order two. These old trucks flex and move between the cab and frame and you might get binding if you only use one joint. Two will give you some flexibility in length too.
#16 |
while i wait on the steering and brake parts, thought i would move forward inside the cab.
stock dash: ![]() removed 2 knobs right of gauges and filled an additional hole: ![]() also worked on the trans hump, paper template: ![]() welded and seam sealed, also took care of a couple other floor issues: ![]() |
#17 |
Registered Chevy Owner
Great build. I love the trans tunnel!
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
#18 |
That is awesome. Loved your other build (builds actually the stuff on KCW and the hamb too).
#19 |
Super nice work!!! Here is a pic of mine sitting on an s-10 frame.
#20 |
thanks everyone!!!
finally some essential parts arrived. worked on the automatic shifting do-hickey. took apart the original 3 on the tree selector and welded it so that only 1 selector moves. cut the other one and rounded it out, you have to keep it cause is supports the shaft. with a universal shift rod kit and a little trimming we have the stock column / shifter now working an auto trans: ![]() steering is connected. using some 3/4 DD, a DD universal joint and a column bearing. in the pics it is only mocked up: ![]() inside the cabin it will all appear stock: ![]() including the accelerator pedal. a cheap spoon pedal and an angle bracket puts the spoon just behind the stock pedal, now the push style original pedal can pull the carb linkage: ![]() last thing will be the brake pedal. that is going to be in form of a CPP kit with booster on firewall. nothing crazy, just something that will work. |
#21 |
Looks good. How are you handling your brake pedal? Firewall conversion?
#22 |
yup, like i said above i ordered a CPP firewall booster assembly. i have a plate to reinforce the firewall as soon as that comes in. when i build these trucks using the stock frame i like to keep it under the cabin like stock with the stock pedal. i might simply cut and weld the actual pedal so it looks original.
#23 |
Nice Work!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe ![]() |
#24 |
subscribed,
like the work. those ujoints look nice. Where did you get em? They are not cheap new. I picked up some slightly bigger looking ones from conversion van at the junk yard. didn't cost much at all. The lower one mounts right up to my power steering and the upper will be connected with the D shaft and then to the stock column, pretty much what you got.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#25 |
thanks fellas! the u-joints i think i got from CPP.
more work done on this rig... took for granted that the owner was using the correct S-10 frame only to find its the wrong length frame. so i had to take 3.5" out of it. decided to do it under the rear cab mount cause i could hide the cut from the side and the plate provided in the chassis kit can be welded to the frame making the new connection stronger, plus i box the inside of the frame at said location. ![]() i made 4 guides on the top and bottom inside the chassis. welded it to the one side after removing the 3.5" then slid the frame back into place using the guides. then weld the guides to the other frame half, followed my clamping the frame walls and welding those. then install the cab mount on the 2 bolt holes the did not change and weld it all the way around. i later moved the bed mounts back the same amount and welded those to the frame as well. ![]() bare frame getting final welds ![]() air compressor mounts (there will be 2) and rear of chassis required the same 3.5" only in length to support the rear of the bed ![]() flipped the frame upside down, to make welding much much easier ![]() trans cross-member tabs (looking at the bottom here) ![]() rear chassis boxing and chassis bag bracket (again looking at the bottom here) ![]() got the motor back from the machine shop! block is a 327, but its built as a 350 with just about all new internals. basically 0 mile motor now. ![]() cant wait to finish assembling the motor! ![]() the frame is currently getting sand-blasted and will receive some black paint shorty after. |
