Need HELP.. Rear axle info
Ok guys, I really need your help with this one. I bought what i think is a camaro rear axle today. I just need help determining if it is from a camaro, what year, and what type and gears. It has a really wierd front housing that i havent seen before (check picture) and came with a torsion or panhard bar setup on it. It does have disc brakes and the standard 5 on 4-3/4 lugs. Any info you guys have would help me out alot. Thanks....
Re: Need HELP.. Rear axle info
More pictures.
Hollister Road Co.
2.34 posi 10 bolt. Camaro had a torque bar bolted on the front of the housing
Certified Car Nut
That is a 7.5 10 bolt. I don't think those came with 2.34 gears, so I'm thinking that is 13:42 stamped on the ring gear (not 18:42) which would give you 3.23 gears which sound about right. But if that is 18:42 stamp on that ring gear I stand corrected. But thats a strange gear ratio to have with a later model 7.5 10 bolt.
Hey kabwe, it is 13:42. thanks for the info. So you think its posi? it has a tab on it that says use limited slip oil only. 3.43. Where does the torque bar attach? ive never seen that before. Do you know where i can find a picture of one? do you guys know what year of camaro this is from? Thanks again guys for the info.
#6 | |
Certified Car Nut
Cancer Survivor in the making.
The cast in bracket on the pinion housing part of the case.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron. Steve@OldSub.com OldSub.com . MaxwellGarage.com . OldGasTowRigs.com |
