02-20-2010, 08:31 PM | #1 |
blazer roll bar and roll cage pics please
i am getting a friend to fab up some roll bars or maybe even a rool cage... if anyone has any pictures or them in there blazer that would be great if you could post them for me. if any one has build there own and has any tips or blue prints that would be great to.
02-20-2010, 10:23 PM | #2 |
Re: blazer roll bar and roll cage pics please
Here are a few pics of mine. I had the front factory roll bar hoop duplicated and then made the mounting feet and everything to mount the new hoop where the factory down bars normally attach. I then attached the front and rear together to give a strong tie. Next step is to tie it into the frame. Only did this becuase at the dunes, they require you to have full protection over the rear seat.
They key to this, was that the front factory roll bar did not have to be modified in any way, but was still used. I still have all the factory pieces for the rear, whenever I want to change it back. Are you thinking of doing a full cage or just the rear? Good luck with the build.
1972 Blazer CST 4x4 Last edited by mdunn; 02-20-2010 at 10:25 PM. |
02-21-2010, 12:55 AM | #3 |
Does anyone have pics & measurements of the factory roll bar?
Dustin '97 Dodge Ram (daily driver) '71 Blazer (supposed to be a toy... insists on being a project) '85 Monte Carlo SS (project) |
02-21-2010, 03:08 PM | #4 |
I got some off my roll bar measuresments go off the inside of the bar and where the bend starts. I hope this helps.
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
02-21-2010, 03:33 PM | #5 |
Not tied into the frame yet. I need to tie into the frame underneath.
Here is a picture before I started. I thought it was the factory bar. Maybe it's not.
1972 Blazer CST 4x4 |
02-21-2010, 04:43 PM | #6 |
02-21-2010, 06:43 PM | #7 | |
Now.... if anyone could make the weather warm so I can take the top off for easier access.... I'm sure shipping kills this but, I have access to a tubing bender- My brother has a bender & all the goodies. I'm sure he would be willing to build made to order roll bars, cages, bumpers, etc built to your specs. let me know if anyone is interested, I can put you in touch with him.
02-21-2010, 12:56 AM | #8 |
what size tubing is that...... 2 inch?
02-21-2010, 01:25 AM | #9 |
Yes, it is 2" x 0.120".
The front hoop is the factory roll bar. That is the one I had duplicated for the rear.
1972 Blazer CST 4x4 Last edited by mdunn; 02-21-2010 at 01:27 AM. |
02-21-2010, 09:51 AM | #10 |
02-21-2010, 12:39 PM | #11 | |
i think i just want to do the front, just behide the seats. your bars dont look like they tie into the frame???? or do they tie in underneath the body? thanx for the pics |
02-21-2010, 10:27 PM | #12 |
Looks like that is/was a Smittybuilt roll bar. I have one just like it. I purchased it from another board member but have never installed it. How are you attatching it to the floor up front? Are those self tapping bolts? I can't see how to get under the floor to use washers and nuts to bolt it in. Let me know. Thanks, Mario.
02-22-2010, 12:07 AM | #13 |
Nope, they are through bolts. You have to reach up and around the frame rail to get to them. They are a pain to get to, but doable.
02-22-2010, 05:21 PM | #14 |
No intent to pick on the really nice work but this in not a stable roll bar set up.
Without cross bracing, it'll fold in a roll over. Last edited by vtblazer; 02-22-2010 at 05:22 PM. |
02-22-2010, 11:19 PM | #15 |
Vtblazer..your point is valid. Did not build this cage to be rock crawler proof. I built it becuase the state parks at the sand dunes say there has to be protection for the rear occupants behind their heads.
How much load do you think the stock roll cage could take bolted to the floor? My guess is it could not handle the weight of the blazer either. Sorry if I lead anyone to believe this is a perfectly safe setup. Was just trying to give Blazin some ideas on where to start.
02-22-2010, 11:46 PM | #16 | |
02-22-2010, 11:58 PM | #17 |
VT's not trying to trash your setup... it looks good... but when it comes to safety, its good to let everyone know that a rollbar like this only looks good- it won't save your life or your passengers life. It's the same for the 'dealer installed' rollbars... they're not going to save your life in case of a rollover. Because it has no cross supports, it can collapse and because it is only mounted to sheetmetal, it can tear out. 50,000 people, or more, have access to this thread, or any thread on rollbars, and if any one of those people gets the idea that a rollbar without the integrity of cross supports or a sound foundation can save their lives, then they are in danger.... and we've let it happen. I'd say that, beyond the force equal to pushing a truck over by hand, a rollbar that is just bolted to the floor with no bracing, just won't hold up. In order to keep you and your passengers alive, a rollbar must be tied into the frame and there must be cross supports and some triangulation. Now, I understand that the trail park has a rule about rollbars, and that's fine.... as long as you know what might happen in a worse case scenario and take the proper precautions as you see fit.
Forget trail riding, it's a good idea to have a cage in a truck that'll only ever see the streets! You're going a helluva lot faster and there are a million more idiots out there! I can't tell you how many times I've thought about wearing my race car helmet just driving to and from work!! Last edited by 1949gmc; 02-23-2010 at 12:16 AM. |
02-23-2010, 12:05 AM | #18 |
ok... it would be aweosme if someone could post a pic or 8 of a safety roll bar setup.. i dont want a full roll cage, it takes away from the look of a convertable blazer. but safety is my number one concern.. otherwise i wouldnt put any kind of roll bar in casue i dont like the look of them. but with my setup ( 383 stroker with 465hp/492tq, 6inch lift) i really think its a good idea to have something. so if anyone has some pics or drawing of a proper setup i would really appreciate them.
02-23-2010, 12:39 AM | #19 |
It's not mine, but something I found using the search feature:
http://67-72chevytrucks.com/vboard/s...87&postcount=6 |
02-23-2010, 12:52 AM | #20 | |
cheers |
02-23-2010, 12:57 AM | #21 |
I'll tell you what, anything and everything you could possibly encounter on one of these trucks is in this board somewhere. It takes HOURS to find it all.
02-24-2010, 12:20 PM | #22 | |
1972 Chevy Blazer 1997 GMC Sierra 2009 Chevy Tahoe Last edited by orange72blazer; 02-24-2010 at 12:20 PM. |
02-24-2010, 03:15 PM | #23 | |
wowwy wow wow wow! this thread needs to be drug back to the top so everyone can see it! |
02-24-2010, 06:13 PM | #24 | |
02-23-2010, 07:24 PM | #25 |
So Many Ideas, So Little Money
not good pics of it, made of 4" truck roll bar
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu Marshalltown, Iowa |
