02-21-2010, 12:33 PM | #1 |
New guy with some questions about my 68 C10
Hello everybody! What a great site! Looks like this is the place for all the info I need. I just recently purchased a 68 C10 Long bed for $1,200! It's a beater but only rust is the rockers and the rear cab corners. I will post some pics soon. I have a couple of questions....
1. What are the stock wheel size for this year and model? And can I use different size wheels as long as they are 6 lug? 2. The gas tank...right behind the seat. Do most of you remove that and put one under the truck? Or is it okay back there? 3. Brakes....I have drums all the way around...should I get disks...or are the drums ok? Thanks |
02-21-2010, 12:54 PM | #2 | |
Happy to be here
Re: New guy with some questions about my 68 C10
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-21-2010 at 12:55 PM. |
02-21-2010, 01:18 PM | #3 |
The Older Generation
to the board. To add to N2TRUX post, all of my trucks have the tank in the stock location. I'm not saying rear mounted tanks are a bad thing, there not. A lot of people are using them. The filler neck location can be a problem but there are a few different solutions. Just read up on them before jumping into the change. As far as the brakes I have both and if done correctly either one will stop you as designed to do. I can't help you on the wheels but someone will. LockDoc
02-21-2010, 01:19 PM | #4 |
Welcome to the board. Tons of info here for you!
Lots of folks are running the 69-72 Blazer tanks behind the rear axle. It's a pretty straightforward setup. I haven't done mine yet, but am planning on it. The disc swap in front is super easy, did it and I love it. I've done the rear also, but that was a bit more involved.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
02-21-2010, 02:40 PM | #5 |
i know that the new chevy 6 lugs are the same bolt pattern 6x 5.5 but the center hole is to small i tried to swap rims with my 04 z71 and the center hole wont fit over the hubs most after market rims are large enough i think the hole is 3.5 inchs and new chevys are 3 inchs
02-21-2010, 03:11 PM | #6 |
HickTown
stock brakes have always done me well on my 68.
and there should be no problem running the gas tank in the stock location
1993 Ford Mustang Vert w/ 2.3 1969 Chevy C/10 w/350 1968 Chevy C-20 w/250 1976 Dodge Aspen W/ 225 2000 Toyota Tundra w/4.7 1987 Dodge Ram D-100 w/360 255/70-15 ___________ (oo)══╬══(oo) ‾‾‾‾‾‾‾‾‾‾‾ |
02-21-2010, 03:23 PM | #7 |
I have My fuel tank in the stock location. Some say they can leak and smell like fuel, but I replaced my sending unit o-ring and it is fine now. My only complaint is the lack of room to put stuff behind the seat. But, I don't drive my 71 that much so I can live with it.
