I just noticed today that my rear brake lights arent working. Both of them are out. Does anyone know what might be wrong? Thanks.
Back in the sticks
Check the bulbs first. Then you have your choice of wires, the mounts that the bulbs are in or the brake switch that the wires go thru. Good luck, and let us know what you find. Jeff.
------------------ 1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer New project 1995 K1500 Sub(Mommas car) 1989 VW Golf(Beater) Will be the daughters car if she will pay her insurance! Ha!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
its all about the +6 inches
Do your turn signals work? If so, the bulbs, grounds, and chassis wires are all good, and the trouble will be in the cab.
Check the fuse, the switch and plug on the pedal, the 1/2 moon connector at the bottom of the column (yes, it goes in there too) After all this, and still no brake lights, then it gets REAL fun. ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. Need to pick up the one ton Longhorn with a PONTIAC 350/350soon. Thanks every one! ![]() Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
1.check fuse 2. check bulbs 3. using a test light check to see if you have power going into the socket. If no power then check the switch on your brake pedal and connections, if power make sure there is a good ground from socket.
If your turn/tailights work the ground is good. Good Luck. CoryM ------------------ 1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070 "Take up our quarrel with the foe: To you from failing hands we throw The torch; be yours to hold it high." Lieutenant Colonel John McCrae, Canadian Army
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070 "Take up our quarrel with the foe: To you from failing hands we throw The torch; be yours to hold it high." Lieutenant Colonel John McCrae, Canadian Army |
Thanks guys. The brake lights were working fine about a week ago. Also, the turn signals do work. I think the problem might be in the cab. I'll check it tomorrow. thanks.
One thing I noticed on my truck is that the connections in the socket are worn down and/or dented in. I need a brand new fresh 1157 bulb with it's raised connections not worn at all to make my LR turn signal stay lit. I just swapped in a new one a week ago. I also have a glove box full of working 1157 bulbs that don't work in my truck.
If you have power back there and you are still scratching your head, try a BRAND NEW bulb. Does anybody sell new sockets?
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
is turn signals are working...therefor, he is getting power to the bulb on that side of the bulb, it just isn't being sent to it from the brake pedal.
| Bookmarks |
