02-21-2010, 02:27 PM | #1 |
keeping rear centered
I am in the process of bagging the rear on my 65 and I really dont want to pay 400+ for watts link so any other ideas? I have maybe a inch in both directions before the tires hit the fenders in the rear. I am keeping the floor stock so everything has to be under the crossmembers. Ive thought about doing a metric type link rear ie olds,monte etc...
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
02-21-2010, 03:16 PM | #2 |
Re: keeping rear centered
I'm also tossing around the idea of the upper wishbone and eliminating the panhard bar. Will this work?
02-21-2010, 05:06 PM | #3 |
I made a sliding wishbone for my truck. It worked out to be the best option for me. Sorry for the crappy pictures.
02-21-2010, 06:09 PM | #4 | |
Yeah, a sliding wishbone is a great way to go.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
02-21-2010, 08:12 PM | #5 |
At the body shop.
Newer dodge durangos have a watts link under them
" That didnt make it any newer " " Dont antique the equipment " |
02-22-2010, 08:44 AM | #6 |
Ya I just noticed that the other day while I was behind one.
Adam M STX Designs Motorcycles | Choppers | Hotrods |
02-22-2010, 12:13 PM | #7 |
Happy to be here
How low are you planning on going? If your not going with a step notch, you don't need a Watts link.
02-22-2010, 10:11 PM | #8 |
No step notch stock floor location but I cant run the 63-64 type panhard bar mounted on right side axle tube because I have about 1 inch of travel twards drivers side. Im running the bags forward of stock location about 12" or so to get more travel out of them. I am wanting to keep the rear centered as possible with the minimal amount of side shift.
02-23-2010, 12:47 AM | #9 | |
FarmBoy.
I'm not much up to date on suspensions and laying low, but would making a custom panhard and moving it to say, the left trailing arm and then to the right frame rail work?
The longer the panhard, the better I've read. Just a bracket (similar to the stock shock mount?) beefed up, a section of rod/tubing and two ends...? Just thinking out loud and trying to keep it simple. -Sam.
1969 GMC C1500. long fleet. 307. 3 on the tree. 3.07 gears. Oliver green. Bent and bruised. Daily Driver. Quote:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993 |
02-23-2010, 01:00 AM | #10 |
I had the supr trackbar on my last truck and it did limit the side to side movement but Still had issues with fender clearence with static drop now I'm going bags I want to keep it centered all the way through the motions that's why I was thinking watts. I know some are saying wheel backspacing and all that jaz but I really like my fat tires.
02-23-2010, 10:59 AM | #11 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-23-2010 at 11:00 AM. |
02-23-2010, 11:24 AM | #12 |
The bags are going to be mounted further forward than stock not trying to get 12 inches of lift. I'm still thinking of putting in stock location.
02-23-2010, 02:04 PM | #13 |
If the front can't get any more than 5" of lift, 12" for the rear seems unecessary. With less lift out back (bags in stock location) the ride is still great & the long Panhard bar should work fine when set up parallel @ ride height. Just food for thought.....
