02-22-2010, 12:33 AM | #1 |
WTB: tach cluster and pedal set
I am looking foor a tach cluster, must be from a 78 or newer, but i would really like an 80s cluster with the newer font, it doesnt matter to me if its from a big truck or if the fuel guage is where the clock is or under the tach, as long as it has one
I am also looking for a clutch pedal set and linkage for a non hydraulic clutch, would also like the bellcrank and the frame pivot. Thanks |
02-22-2010, 01:20 AM | #2 |
Roadtrip!
Re: WTB: tach cluster and pedal set
What is the easiest way to tell the year? I know the volts/amps and oil gauges narrow it down. I can check a couple of clusters i have here.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
02-22-2010, 08:58 AM | #3 |
02-22-2010, 01:30 AM | #4 |
If I am not mistaken, the 80's will have 85mph speedo, 78 & 79 will have 100mph.
How many tach clusters do you have?
87' GMC 1/2 Ton 4x4 SB, 350TBI/700R4, 4" Lift on 35's |
02-22-2010, 01:44 AM | #5 |
Roadtrip!
I have a few clusters here. I know about the 85 to 100 mph part. What year did the electric oil gauge come in? How about the volts to amps change? I think the earlier ones had a date code on the PC, but not sure on the later ones..
02-22-2010, 02:16 AM | #6 |
02-22-2010, 02:32 AM | #7 |
Real Projects never die
77 is first year for volts, only year for volts and mechanical oil pressure, then 78-79 were electric oil pressure, 80 and up 85mph new font.
id love to find a 77-79 c60 cluster with the fuel gauge inside the tach in good shape. Hope this info helped you narrow it down.
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
02-22-2010, 08:55 AM | #8 |
yep, all that is right, i need one with an electric oil gauge and would really like the newer font
02-22-2010, 10:25 AM | #9 |
Performance Shop Owner
1980 was the first year with "orange" highlights instead of "baby blue" as well, thats the easiest dead give away to tell on the tach and speedo.
1980 GMC C25 Sierra Classic with 20,000 ORIGINAL MILES (32,000Km's) & Matching numbers 1977 GMC C35 Sierra Classic Crew Cab 454 A/C with 21,000 Miles & Matching numbers 1980 Chevrolet Silverado K20 400 4spd 4X4 74,000km's 1980 GMC C25 Sierra Classic CREW CAB, All Options, with 49,000 Miles 1979 GMC C15 Sierra Classic 454 1989 GMC R3500 CREW CAB 2003 Grand Prix GTP 1998 Regal GS |
02-22-2010, 07:33 PM | #10 |
The different font does it for me, huge difference right there.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
02-22-2010, 09:51 PM | #11 |
Roadtrip!
Ok, i looked through a few and i have one with the electric oil gauge in nice condition. It is the 78-79 style i believe. (100 mph speedo) I will have to do a little research to find a value on it. I also have a newer font one out of a bigger truck with a 4K tach, but that won't be cheap...
02-22-2010, 11:43 PM | #12 |
I have a few of the blue highlighted 78-79 tachs, but I haven't had a chance to test, clean, and paint the housings.
How soon are you wanting one?
CHEVY ONLY |
02-22-2010, 11:50 PM | #13 |
i want want on soon, but i dont need one soon. ill probably wait for an 80s cluster and if i dont get one or depending on the price i will settle for a 78-79
02-22-2010, 11:45 PM | #14 |
how much for the big truck cluster? and is there anything in the lower left spot? pics please?
i really like the newer font... |
02-23-2010, 12:11 AM | #15 |
The electronics and mechanics are identical between the blue and orange highlighted tachs. I believe the font is even the same (I'll have to compare to be sure). I have thought about getting new overlays with the orange or painting over the blue. Sorry I'm
not further along to be able to help you out..... EDIT: the font is different. This one is smaller and fatter, guess I'll have to do some experimenting.
CHEVY ONLY Last edited by joe231; 02-23-2010 at 12:19 AM. |
02-23-2010, 12:40 AM | #16 |
no thats fine. its good to see that you are coming up with solutions, and some things take time to get good quality. i wish you the best of luck with the overlays
02-23-2010, 09:13 AM | #17 |
The cluster that I had in my 87 was from a 79, got the white overlays and looks just like the 80s font. The sweep of the gauges is the same between the two, just the speedo is different, obviously being 100 to 85 mph.
The one cluster I have now is from a 70s with the fuel gauge in with the tach, I plan on getting the overlays for that, won't be able to tell the difference. Dunno if I want a vacuum or clock were the air pressure gauge is.
02-23-2010, 09:17 AM | #18 |
do you buy the overlays? or do you make them?
02-23-2010, 09:36 AM | #19 |
02-23-2010, 09:46 AM | #20 |
thank you
02-23-2010, 02:45 PM | #21 |
Roadtrip!
Here are some i have with an electric oil gauge. If you see one that intrests you i will give you more info and pricing. $135 and up depending on which one.
02-23-2010, 05:26 PM | #22 |
im interested in the the first 2, is that just dirt on the first one?
02-23-2010, 07:42 PM | #23 |
Roadtrip!
Yes, just many years of dust. I don't clean these at all, just took the lenses off to get decent pics. The gauges look good under the dust. (no rust that i can see, but will look them over better). I will add a couple of pics tonight for you...
02-23-2010, 11:28 PM | #24 |
alrite sounds good. thanks
02-24-2010, 12:16 AM | #25 |
Roadtrip!
Sending PM...
