Old 02-24-2010, 10:13 AM   #1
NicoSlam
Polished Grill before after
Well I decided to polish the grill on my 69 since it looked bad against a new chrome grille. The grille was a solid 8 with only one dent on the pass side. I started by removing the grille and tapping out the dents as best as possible. I then used easy-off to remove the anodize. after a good cleaning, I went over the whole grille with 600grit and wd40 to smooth out any scratches etc. followed with 0000 steel wool to smooth out and give a uniform surface appearance. The next was the fun stuff. I used a 4" medium buff wheel and tripoli (brown) and did most of the work with this compound. I cleaned the surface to remove and residue and followed with a new loose wheel and white rouge to remove any haze. Finally I polished the grille using an aluminum polish I found at outzone. Not the show quality results but the grille compliments the bumper pretty darn close. As for the inner grille, I painted the surface with silver, let it dry then taped it to protect it and from the back side I painted it black leaving the look use see in the pic. Overall it took about 7hrs but well worth cost savings of a new grille. Here are some pics. Hope you like.
NicoSlam is offline   Reply With Quote
Old 02-24-2010, 10:20 AM   #2
junkman
Re: Polished Grill before after
looks great, I have one that needs the same treatment. So did the easy off take off the anodizing pretty well? I have tried a couple things on mine and the only thing I could get to take it off was sandpaper, even tried spray can paint stripper.
junkman is offline   Reply With Quote
Old 02-24-2010, 10:32 AM   #3
OARNGESI
OARNGESI's Avatar
looks realy goog
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 02-24-2010, 11:03 AM   #4
chas350
Nice!
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 02-24-2010, 11:02 AM   #5
DT1
DT1's Avatar
I'm in the process of doing my grill on my 71 C-10.
I tried Easy off and White lightning to remove the anodizing but neither worked all that well. If you want to remove the anodizing quickly, use a 20:1 mix of water and sodium hydroxide (lye). Put it in a spray bottle and liberally coat it. Let it sit for ten minutes and use a Scotchbrite pad. Repeat and done.
DT1 is offline   Reply With Quote
Old 02-24-2010, 11:43 AM   #6
Brad
Out of the carpool lane.
Brad's Avatar
That looks fantastic!! I'm not a fan of the 69-70's because of the grill, but I wouldn't mind owning that. Wow!
Ok, after looking at it closely again I'd say you really need to clean up the black overspray on the grill and headlight buckets. In fact, I think it looks way better with the headlight buckets polished instead of painted like you did.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 02-24-2010, 12:00 PM   #7
big_al_71
big_al_71's Avatar
That looks really good, definetly worth the effort...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 02-24-2010, 12:02 PM   #8
NicoSlam
thanks for the comments. I also didn't like the black headlight rims. Looked like the truck had black eyes. I wasn't too pleased with the quality of the aluminum bezels. They were shiny but very thin. Anyway, I dont plan on hitting them so it should be fine. I'll try the 20:1 water lye on the trim next. easy off wasn't the best but better than elbow grease and sandpaper.
Old 02-24-2010, 12:24 PM   #9
robzilla
robzilla's Avatar
where can you buy lye? as i need to do my grill too.
robzilla is offline   Reply With Quote
Old 02-24-2010, 12:35 PM   #10
DT1
DT1's Avatar
EBAY...$8.00-10.00 for a 1 Lb container.
Caution!!! This stuff will Eff you up! Wear eye protection and gloves.
Old 02-24-2010, 01:06 PM   #11
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Some hardware stores keep it in plumbing sections. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-25-2010, 05:16 PM   #12
D-Rat
D-Rat's Avatar
LMC Truck sure likes the 69-70s....a new grill shell in their catalog is $1150 vs something like under $400 for a 71-72. Crazy.
1970 CST with a screaming 400
www.nissan4wheelers.com
D-Rat is offline   Reply With Quote
Old 02-24-2010, 03:13 PM   #13
Hart_Rod
Hart_Rod's Avatar
It looks great! Have you thought about shooting a coat of clearcoat on it to preserve the shine?
Hart_Rod is offline   Reply With Quote
Old 02-25-2010, 03:47 AM   #14
Brad
Brad's Avatar
Thumbs up Re: Polished Grill before after
Hey, I also noticed the chrome bumper isn't there anymore. Why did you take it off? It looks really good with your blingin' grill!
I did a little 'paint' for ya and I think this would make the grill perfect:
Old 02-25-2010, 04:31 AM   #15
67ChevyRedneck
67ChevyRedneck's Avatar
I think the last pic was his "before" pic.
I like it, good job
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-25-2010, 09:46 AM   #16
rockc
That is a nice job. What kinda paint did ya use for the lettering?
72 chevy 3/4 ton 4X4
rockc is offline   Reply With Quote
Old 02-25-2010, 10:12 AM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
That turned out awesome.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-25-2010, 03:11 PM   #18
NicoSlam
I do plan on adding the stripping this weekend. It would cover areas I just couldn't reach with the buffing wheel. I'll post update Saturday.
Old 02-25-2010, 04:31 PM   #19
1971ChevyTruck
1971ChevyTruck's Avatar
Looks good!!
1971ChevyTruck is offline   Reply With Quote
Old 02-25-2010, 09:49 PM   #20
stueber68
1968 C20 Vortec Beast
stueber68's Avatar
How about using an aerosol clear coat to seal it and easier to keep clean?
Ugly or not it still kicks a**!
stueber68 is offline   Reply With Quote
Old 02-25-2010, 10:17 PM   #21
70Custom10Nut
70Custom10Nut's Avatar
Looks awesome! Now I know how to do mine, but I have the same question about protecting your hard work. Will clear paint work? If not are there any products that will? Cnut
70Custom10Nut is offline   Reply With Quote
Old 02-25-2010, 10:26 PM   #22
70Custom10Nut
I'll bet someone could do all his trim the same way. A little time, patience, and elbow grease can save about $2000 in new trim costs. Cnut
Old 02-25-2010, 11:17 PM   #23
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
wow looks great!!!!! good job!
John
1999 Toyota Tacoma 4x4
