![]() Join Date: Jul 2009
crossmember swap question
Ok I know this subject has probably been beat to death but I have a question that I can't find an answer for.
I have a 69 c10 with the 4 wheel drum manual brakes. I bought an 87 suburban to do the crossmember swap so I can get the power disc brakes for my truck, the gas tank & the 700r4 transmission. I'm just about ready to do the swap and am wondering if I can unbolt the entire crossmember as a whole assembly or do I need to remove components to successfully remove the crossmember? I need to do this swap as quickly as possible because the HOA will flip out if I have a tore down suburban sitting in my driveway. Any tips or ticks would be greatly appreciated. |
#2 | |
Re: crossmember swap question
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-25-2010 at 03:44 PM. |
#3 | |
Thanks scoti |
Sounds simple until you try & manuver that mass of stuff around (do-able, but can be a PITA....). Since I usually rebuild as I go, I leave the factory c.member in & swap the rebuilt stuff over piece by piece.
Will the newer stuff bolt on to the older crossmember? I thought in order to use the newer stuff you had to use the crossmember. If I can just swap the parts & keep the factory crossmember i'd rather do that.
Yes, the newer stuff will swap right over to the current drum brake crossmember. If you want to use the 'correct' diameter u-bolts to retain the lower a-arm shafts (which I recommend) you need to drill the u-bolt holes out to the larger u-bolt size (I believe they're 1/2" u-bolts on the drum trucks, 9/16" on the disc trucks). The smaller ones can be re-used too & then drilled out once you get things together which will help keep the HOA out of your face.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-25-2010 at 07:08 PM. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
If your dealing with the hoa id just unbolt the whole thing and swap it out that was its faster...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
