TUKE-NoBullChit Customs owner
85-86 fuse box diagram or labeled pic please!!!
the trucks birthdate is oct 18, 1985 so im guessin my body is really a 86?
im still having a problem getting a few of my guages to work. thing that stumps me is that the clock works. i know the oil pressure one isnt even hooked up at the engine because i havent put in the correct sender in. the tempguage i still need to try the correct sensor, but my battery guage does nothng either. could this just be a fuse and the clock is on a separate circuit? just wondering because none have ever did anything. and do these all have to be hooked up for one of them o work, like the power window switches are? im thinking a fuse diagram would help since the letters are damn near all gone on mine. thanks in advance. ![]() |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Re: 85-86 fuse box diagram or labeled pic please!!!
I can get you one tonight when I get home if no one gets you one before hand.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
haha, ford guys...
well this is a basic one for our trucks,im not sure if this is what you are looking for?
# A - Fuse - Traffic Hazard # B - Fuse - Tail, Stop Courtesy Lamps # C - Receptacle - TP2 /M40 # D - Fuse - Radio & TCS # F - Receptacle - C91/UF2 (Cargo Area Lamp)/U35/U37 # G - Fuse - Heater / Air Cond. # H - Receptacle - C62 # I - Fuse - Accessory # J - Fuse - Panel Lights # K - Receptacle - NL2/A33/U16 (Tachometer) # M - Receptacle - Accessory Lamps # N - Not Used # O - Fuse - Reversing Lamps # P - Fuse - Instrument Cluster Feed |
cool. well i got the oil pressure and temp guages working now, but have no clue if the temp one is reading correct. i did swap the original guage backin, it readsbelow the 200 mark, and i think thats normal. still cant get the voltmeter to work, but im going to check the brown wire from the alternator lster on.
by the way, thanks again. the diagram was spot on. |
