Old 02-25-2010, 11:34 PM   #1
draggin86
draggin86's Avatar
73-87 drive shaft clearance
Hey guys I haven't put my drive shaft in yet.. Those of you who are bagged are you dealing with anything cab clearance issues.. If so are you guys running 2 piece dive shafts?
Thanks alot guys!
Billy
draggin86 is offline   Reply With Quote
Old 02-26-2010, 12:08 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 73-87 drive shaft clearance
I had to look up your build thread to see what your truck was. In "most" 73-87 applications the cab is not an isssue like the 67-72's. In your case all bets are off. With the set up your running, it might be necessary to go two piece.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-26-2010, 01:37 PM   #3
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I had to cut a small amount out of the bottom of the cab on my ride. The motor is in the stock location.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-26-2010, 09:14 PM   #4
draggin86
draggin86's Avatar
Ok I should be laying on a 20" wheel with a 285/30/20 more wis would be stock location with a 4l60e.. If that helps any!!
